CMS Presents BC Racing Coilovers ~ Now for IS250 AWD & ISF!
Circuit Motorsports is proud to provide the Lexus club with BC Racing Coilovers!
We are the only shop to carry the exclusive AWD IS and GS versions of these awesome coilovers. Not to mention that BC Racing is the only manufacturer to produce a coilover for this application. We heard your cries for help and we responded, here they are!
We also carry BC Racing coilovers for these Lexus applications:
-08+ ISF
-'98-'05 IS-300
-'06+ IS-250 and IS350 & AWD
-'92-'97 GS300/350/400
-'98-'05 GS300/350/400
-06+ GS Series & AWD
-'92-'00 SC300 and SC400
-'95+ LS400/430
-'00-'07 LS430
BC Racing BR series coilovers are perfect for street driving and occasional road course duty. With easily accessible adjustment ***** for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and the patented concave lower locking ring keeps it locked in. They are dual-height adjustable, which means you don't sacrifice shock travel when you lower the car, since spring preload is completely separate from ride height. We can provide them with the OTS spring rates, or you can choose a softer or stiffer setup, it's up to you. We make it extremely easy for you to customize your suspension for your car.
We also provide the option of pillowball mounts front and rear, or rubber mounts front and rear, your choice. Rubber mounts provide an extra barrier between your suspension and chassis, reducing NVH. Pillowball mounts will be a little noiser, but they provide better feedback through your chassis and a stiffer mount for those of you looking to track your cars.
Here are the specs:
General
-Mono-tube shock design
-30 levels of damping force adjustment
-Separate Full length height adjustable
-Pillowball front mounts
-One year warranty
-Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
-Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
-Patented concave lower locking ring, to prevent unseating
-Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
-T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
-Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
-High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
-2 step coating process utilizing nickel and chromium plating to prevent corrosion
-Newly developed lubricant oil in all shock cartridges minimizes aeration and cavitation.
-An additional bearing beneath each pillowball mount provides a smooth action and prolongs the life of the pillowball itself.
-Each BC damper is individually dyno tested before leaving the factory, making sure each damper is matched to within 5%, ensuring an equal balance in handling. OEM standards are 13% in comparison.
We beleive in "Affordable Performance", so we are giving these to you guys at an awesome sale price, just PM us for a quote. Include your vehicle type and year, and if it is RWD ior AWD. These are an awesome deal at this price and you can't get this kind of quality coilover with these features anywhere else.
We also can privide suggestions on street and track setups, suspension advice and plans and general setup specs, we know our suspensions!
WE GIVE THE BEST DEALS AND PACKAGE PRICES ON BCR COILOVERS!
Feel free to PM or email with any questions or orders!
T.
sales@circuitmotorsports.net
AIM - circuitms
http://www.circuitmotorsports.net
Want to adjust your damping on the rear coilovers without tearing apart your trunk? Get Extenders! These little cables attach to the adjuster **** and can be punched through the trunk liner to give you damping access for super easy adjustment!
Ok, some of you have been asking about BC Racing coilovers and where they came from. So here's a brief history and some of the achievements they've made as a company and race team.
BC has been manufacturing coilovers since 1999, so they are not new to the game. They have years of experience designing, testing and building full coilover systems. They know what works and what doesnt. They also have TUV approval for their manufacturing and management process, which is not an easy award to be granted.
BC Racing North America has been campaigning their G35 Time attack car over the last year and plans on more events this season. Last year they competed in Modifieds Tuner Shootout and grabbed 2nd place. They competed in Multiple Super Street Super Lap Battle and Redline Time Attack events, and have achieved many podium and first place finishes in these arenas. All while running on BC Racing coilovers, and not some crazy one off suspension either, they use OTS parts to prove they work. So customers can see the results and purchase the same winning coilovers for themselves.
There are also multiple time attack teams running, and winning on, BC Racing coilovers. Topspeed, Element Tuning and DS1 motorsports are a few.
BC Racing has a huge Subaru following, with over 1000 happy customers in just that community.
Basically, BC Racing is a company that continues to grow and bring awesome new products to the enthusiast community. Products that they stand behind and are proud to offer.
A pic of the G35 in action:
-08+ ISF
-'98-'05 IS-300
-'95+ LS400/430
-'00-'07 LS430
Here are the specs:
General
-One year warranty
T.
AIM - circuitms
Free bump cause im the 1st to have these plus Pete and Tristan were a big help to make this happen big up to BC Racing for comming threw and the ride quailty so great some people dont even notice im on coilover but im switch rubber mount soon as weather get better here
We tried to keep the cost down, but since this was a special run of coilovers the manufacturing, etc. raised the price a bit.
Glad we could work with BC to get these out to you guys though
