View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 12-20-04, 08:16 PM
PandaAE86
PandaAE86's Avatar
Default LS brakes do not fit GS!!!! :(
I'm sure many of you guys out there have seen IS and SC install LS400 brakes and also Supra TT brakes. Well, just for the record, the LS brakes DO NOT fit 2rd Gen GS!!!!
The following pictures will show what didn't fit.
btw, now they're up for sale. If you're looking for this setup for your SC or IS, PM me. I have the calipers and Rotora slotted & drilled rotors.
After looking at it for about 30 mins or so, I found a way to fit them. Very simply to do, no cutting or grinding required.
Attached Thumbnails LS400 brakes do fit 2nd Gen GS!!-1.jpg   LS400 brakes do fit 2nd Gen GS!!-2.jpg   LS400 brakes do fit 2nd Gen GS!!-3.jpg   LS400 brakes do fit 2nd Gen GS!!-4.jpg
BHustle84 (11-06-23)
Old 12-20-04, 08:32 PM
alredxiii
alredxiii's Avatar
Funny?
How come Supra Brakes will fit?
Same 4 Pots....hmmm wonder....
Old 12-20-04, 08:37 PM
Neo
The One
Neo's Avatar
This is on a GS:
Contact jawnthen for details as this is on his car.
Amel2jzgte (05-01-20)
Old 12-20-04, 09:49 PM
rominl
exclusive matchup
rominl's Avatar
yeah i don't know, but jawnthen put ls400 brakes on his gs no problem?
also, the brakes will not fit the is3 for sure. the is shares different brakets from that for the gs/sc
alredxiii, they are not the same. the supra tt, the ls400, and the ls430 they all have different brakes
for the record the ls430 calipers they won't fit on the 2nd gen gs
Old 12-20-04, 10:02 PM
PandaAE86
PandaAE86's Avatar
well.... I took the pictures of where it didn't fit. it was totally pressing against the knockle. From what I remembered, I checked and double check that I had the Left caliper on the Driver side.....
Darn it!!! THIS SUCKS!!!!! What am I doing wrong???
Old 12-20-04, 10:05 PM
rominl
exclusive matchup
rominl's Avatar
umm if you want try to pm rmmgs4 about it, i think he helped the isntall or something
jawnthen is way too hard to reach
Old 12-20-04, 10:09 PM
PandaAE86
PandaAE86's Avatar
It seems like it's just a straight bolted on (with the expection of cutting the dust shield). Maybe I'll try it again tomorrow....
Old 12-20-04, 11:02 PM
johnee78
johnee78's Avatar
Wink
If you want those calipers to fit, contact me through PM or email and I will help and tell you how they WILL fit..
johnee78@bellsouth.net..
Old 12-20-04, 11:04 PM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
Yeah,
I had to perform some "magic" to make them fit on Jawnthens car.
I trimmed both the steering knuckle bolt and just a little of the caliper.
Not technically a good thing to do, but Jawnthen was "committed" to make them fit.
We installed the calipers umpteen times and I just kept shaving the corner of the bolt until it cleared. I used a dremel, with kevlar blades and a very steady hand .
One word of caution, don't cut into the caliper body too much since you can cut through to the brake fluid reservoir !
Johnee78, if you have another way to do it, please share with us.
One more note. The LS rotors are NOT the same diameter as the TT rotors. LS are slightly smaller.
Tjaii (06-14-21)
Old 12-20-04, 11:11 PM
johnee78
johnee78's Avatar
Originally Posted by RMMGS4
Yeah,
I have a way to install the calipers without trimming..I can't reveal how just yet but I will in private for now..
Old 12-21-04, 01:49 AM
jtanoyo1
jtanoyo1's Avatar
I got the LS430 monoblock aluminium calipers conversion on my car, but they take special nickel-cadmium alloy brackets made by DSR to get them to fit. IF you got the brackets, install is a breeze and just like any other big brake kits.
Old 12-21-04, 01:34 PM
LexFather
Guest
Posts: n/a
Yeah, it has to be a custom job. There is a guy in Atlanta that has LS 400 brakes on his IS. He told me it had to be custom like ya'll did.
Old 12-21-04, 02:15 PM
rominl
exclusive matchup
rominl's Avatar
any reason why?
Old 12-21-04, 02:16 PM
rominl
exclusive matchup
rominl's Avatar
Yeah,
ok so it's not direct fit then. in that case i wouldn't call the ls400 brakes a bolt on at all. far from it actually. personally i wouldn't feel safe doing that to get the brakes to fit
KingChris (07-25-17)
Old 12-21-04, 06:13 PM
RMMGS4
RMMGS4's Avatar
Well one way to get the calipers to fit is to rotate the caliper slightly towards the 12 o'clock position so it doesn't hit the steering linkage.
This would require a custom bracket and probably what jtanoyo1's set up does.
There's another way, but I'm not telling either !
Quick Reply: LS400 brakes do fit 2nd Gen GS!!
