I have a problem in the VSC & VSC OFF
Old 06-11-10, 03:43 PM
shadi
shadi's Avatar
Question I have a problem in the VSC & VSC OFF
Ih I have a problem in the VSC & VSC OFF. I own a car-type GS 300 moodle 2004. The car does not exist problems but I wanted to check because I was traveling by it . After that I took the car to the workshop to the test by computer. Thank god were not by any problems with it. While you are departing from the workshop the light of VSC & VSC OFF is on. I returned to the engineer to tell him but he did not know what this problem. I check on all the sensors, there is no problem with and reset the computer but without any solution found.
notice
When you start up the car no light of VSC & VSC OFF but when the move the car the light is on.
please help me, because unable to resolve it and the company takes a lot of money.
Old 06-12-10, 09:50 AM
shadi
shadi's Avatar
No one can help me...!!
Old 06-12-10, 10:41 PM
Red Bully
Red Bully's Avatar
I have the same issue i now need a abs pump its more than lightley the master /abs pump
Old 06-13-10, 06:33 AM
shadi
shadi's Avatar
ABS pump...!! I don't think so, Because the problem came suddenly when I left the workshop after examining the car.
I think the problem of the device that the car was examined by. Has led to problem in the system or programming of
a car but I could not be resolved, and I want one help me to finding a solution as soon as.
Thank you for your interaction with me, Mr.Red Bully
As I would like everyone involved to find a solution. I know that there are a lot of people here have good experience,
I hope their participation with us.
Old 06-14-10, 03:06 AM
ydjy
ydjy's Avatar
Error codes?
Old 06-14-10, 02:20 PM
shadi
shadi's Avatar
Thank god, I found the solution....
The solution is re-programming of the system ABS ( Zero Point Calibration ) .
The solution consists of approximately 15 step .
NOTE:While performing the Zero Point Calibration, do not tilt, move or shake the vehicle.
The vehicle must remain in a stationary condition throughout the entire process.
Be sure to perform the procedure on a level surface with an inclination of less than 1%.
Explanation of symbols:
SST (4-inch wire)
DLC3 (OBD-II connector under the dash)
TS (on the top row,pin number 3)
CG (on the bottom row,pin number 5)
(See picture below)
1. Ensure the shift lever is in the ''P'' range.
2. Turn the ignition switch Off.
3. Using SST 09843--18040, repeat a cycle of short and open between terminals Ts and
CG of DLC3 4 times or more within 8 seconds (refer to the specific vehicle EWD for
TS and CG pin location in the DLC3).
4. Turn the ignition switch ON, do not start.
5. Verify that the VSC indicator light is lit indicating the recorded zero point is erased.
6. Turn the ignition switch OFF.
7. Be sure the terminals Ts and CG of DLC3 are disconnected.
8. Turn the ignition switch ON, do not start.
9. Check that the VSC warning light goes off about 15 seconds after the ignition switch
is turned ON.
10. After ensuring that the VSC warning light remains OFF for 2 seconds, turn the ignition
switch OFF.
11. Connect terminals Ts and CG of DLC3 using SST 09843--18040.
12. Turn the ignition switch ON, do not start.
13. After turning the ignition switch ON, check that the VSC warning light is lit for about
4 seconds and then starts quick blinking at 0.13 second intervals.
14. After ensuring the blinking of the VSC warning light for 2 seconds, turn the ignition
switch OFF.
15. Remove the SST from terminals Ts and CG of DLC3.
16. Drive the vehicle for at least 5 minutes to confirm Zero Point Calibration is complete.
Thank God, experimented with the road and returned the system operates.
If you have any question on the way, I'm reply
Shadi
Milt61 (02-17-24)
Old 10-02-10, 03:32 AM
Mickb5
Mickb5's Avatar
This saved me a fortune thanks, I was convinced my problem was a wheel sensor, tried this and cleared it
Old 10-02-10, 03:59 AM
denIS200
denIS200's Avatar
Thumbs up
The error is c1336
https://www.clublexus.com/forums/gs-...ode-c1336.html
Denis.
Old 10-02-10, 12:09 PM
sam430
sam430's Avatar
Got curious ...
Check under rsteering column, no such pins.
Top 1,2,4
bttm 2,4,5 available to short
Old 10-07-10, 02:19 PM
MartijnAms
MartijnAms's Avatar
Is this for real? I want to try this, as I suspect my ABS system, but I don't want to break even more.
Thanks for the reply.
Old 10-11-10, 05:46 PM
alan311
alan311's Avatar
Got a 2002 ES 300 and I had the same problem. I fixed the thing by doing the thing in user Shadi's post above. All you need is a jumper wire and flashlight. Be sure to connect the right terminals and follow the procedure as explained.
Old 10-11-10, 06:00 PM
alexdan
alexdan's Avatar
i dont have this problem ....but sure saw it around a lot..... god bless the turkey guy for the people that this little simple procedure takes care of that problem....
Old 10-28-10, 12:00 PM
porn-adkt
porn-adkt's Avatar
pin outs are different for 2000 GS4? no such thing as the posted pic. anyone have the correct Tc and Cg for a 2000 gs4
Old 10-29-10, 09:28 AM
sakataj
sakataj's Avatar
why bump this and then make a new thread?
https://www.clublexus.com/forums/gs-...obd2-help.html
now people searching for it will find multiple ones....
while OP hasnt been on in 2 months have you tried to PM him so when he does get in he can help you?
Old 10-29-10, 10:49 AM
porn-adkt
porn-adkt's Avatar
Why? because one pertains to the ABS, VSC warning light the other to the Pin out it self. which by the way i was planing on posting some new info on how to do it from the DCL1, but your comment makes me think twice about posting.
Didn't know it bothered you that much, but you can always have a mod Lock it up.
Quick Reply: I have a problem in the VSC & VSC OFF
