Go Back   Club Lexus Forums > Lexus Model Forums > GX 470 Model
Thread Tools Display Modes
Old 12-10-07, 07:59 PM   #1
Jrajkumar
Trader Score: (0)
Default deep hum at around 1600 rpm
When the rpm reaches around 1500 in my GX 470, i hear deep roar as though it is straining to pull. It is not loud. It is just a deep engine noise inside the car. You have to listen carefully to hear it.
I am not sure if it is normal. I am worried. Can anyone explain if it is a problem and if so, what kind of problem it is? I live about 4 hour away from the nearest Lexus Dealer.
Thanks for your consideration.
Jrajkumar is offline   Reply With Quote
Old 12-10-07, 08:27 PM   #2
brickauto
Trader Score: (0)
brickauto's Avatar
Try searching for "drone", there is a TSB (ST3010) for a low rpm droning/vibration issue with the GX470, I have an appointment set up for next Monday to have this issue resolved. It is covered under the 4yr/50k warranty.
brickauto is offline   Reply With Quote
Old 12-11-07, 05:06 AM   #3
super_cjc
Trader Score: (0)
It might be covered by the 6yr/70K powertrain warranty.
My GX has 60K miles but dealer still applied the updated "clunk" fix for free.
__________________
08 IS250AWD Matador Red Mica
04 GX470 Silver Pine Metallic
#03 GX470 Silver Pine Metallic(gone)
#99 RX300 AWD Millennium Silver Metallic(gone)
super_cjc is offline   Reply With Quote
Old 12-11-07, 09:26 PM   #4
brickauto
Trader Score: (0)
brickauto's Avatar
The clunk fix is covered under the 6yr/70k powertrain warranty.
The drone however is covered only up to 4yr/50k, as seen in the TSB (the TSB number has been superceded to ST3010)
Old 12-12-07, 04:11 PM   #5
Jrajkumar
Trader Score: (0)
Hi - Thank you for your reply and the TSB. My Gx 470 is 2006 make. I was wondering if any TSB that applies to 06 model reg this issue exisits.
Thanks again.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
