Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#5311
^^^ Those sizes would be just fine. They would yield a small stretch and you should have no problems with rubbing as the tires would definitely tuck under the fender on bumps. The fronts would also be very flush with the fender-it should not stick past it.
#5315
#5316
Hello I did a search was no luck on the size/offset question I have, with 18x9.5 all around with a +25 offset what tire size should i run??? (with stretch)....and to what extent will I need to roll/pull the quarters/fenders....thanks in advance.
#5317
with those offsets, no pull required. depending on how low you are, you may need a slight roll to no roll if you stretch tire i.e. 225/40/R18 or 235/40.
#5321
@toyoboy......I might actually have to take that option. I'm not sure about my left quarter, I think it might have some body filler in or around the wheel well....I did my MK3 supra like that for that very reason...
#5323
#5324
#5325
