hood shocks?
Old 03-03-02, 02:24 PM
cutecboy
cutecboy's Avatar
Question hood shocks?
some one posted some info about hoodshocks for 90-94 ls, like where to buy them for fairly cheap price for some brand new one's, can that someone post it again? or leave a # or website?
thanks alot..
Old 03-03-02, 04:27 PM
jahummer
jahummer's Avatar
try this
https://www.clublexus.com/forums/sho...threadid=31885
Old 03-03-02, 07:43 PM
GTPED
GTPED's Avatar
I just replaced these myself on my 95 ls400. I cut off the stock hood struts with a dremel (carefully) and replaced with a set from a local auto store. The new struts slipped right over the stock "ball" and are held on with a snap clip. Took 15 minutes total and they work great. The brand was Mighty and the # I used is 95029. Good luck!
Ed
Old 11-23-02, 10:55 AM
New Owner
New Owner's Avatar
Ed, could I get you to go into a little more detail here?
Where are you "cutting" with a Dremel tool and what type of blade or bit?
The originals on my '96 are shot, tho the car is otherwise in pristine condx, only 49k miles. Coming up due for the 50k mile checkup and it'd be nice to have the hood stay open without spending hundreds. Bracing it open with a 2 x 4 is kinda ghetto..
Thanks
Old 11-23-02, 09:02 PM
Lexozz
Lexozz's Avatar
Ok guys this is the brand and model to use. $19.99 @ Autozone.
Old 11-23-02, 09:09 PM
Lexozz
Lexozz's Avatar
And the drill bit is 5/32, you can see the hole right on top of the old hood strut, that's where I drilled.
Old 11-24-02, 03:05 AM
retrodrive
Search Function Inc.
retrodrive's Avatar
I did everything the same way couple days back...I never thought that anything can lift that hood! It was heavy as hell. Now it just goes up by itself
Old 11-25-02, 02:15 PM
hyperopt
hyperopt's Avatar
I have been trying to locate the hood support C95029 at my local Autozones for days and none stock that number. Their lift support selection is too few.
Retrodrive: Which Autozone in San Diego did you find the item? I visit S. D. often and would like to pick up a set on my next visit.
Old 11-25-02, 06:11 PM
retrodrive
retrodrive's Avatar
That was AutoZone on ElCajon Bulevard exit. There are at least 3 of them at that spot so it is goin to be hard to find. I will actually need a pair of supports for my trunk so I can pick up an extra pair for you.
Old 11-25-02, 11:25 PM
SharpLS-96
SharpLS-96's Avatar
Got this from www.Autozone.com
LIFT - HATCH/HOOD/TRUNK
MIGHTY-LIFT LIFT - HATCH/HOOD/TRUNK
Unit Price: $15.99
Core Value*: $0.00
Part No.: C95029
Weight: 0.00 lbs.
Warranty: LLT
Availability: Online: Ships within 2 business days
Store: Not Available.
Old 11-26-02, 03:53 AM
LOTC
VIP 様式
LOTC's Avatar
Wow only $15.99 compared to the $120.00 the dealers charge!:eek:
Old 11-26-02, 01:48 PM
hyperopt
hyperopt's Avatar
Retrodrive:
Thanks for the offer! I see if I can order a set from the net first.
Old 02-11-03, 11:00 PM
FaceUT
FaceUT's Avatar
I was unable to find this number on the website for autozone, however my local autozone had the hood supports in stock!
Anything special I need to know about installation?
Old 02-11-03, 11:33 PM
retrodrive
retrodrive's Avatar
Yah, check your PM. I have a howto for that. Pretty straightforward.
Old 02-15-03, 06:06 PM
ychachad
ychachad's Avatar
Just performed this operation. Works great. This has been a fantastic thread. One word of advice; keep a 50 pack of dremel cutting disks handy. I went through about 25 or more to cut the ends off. And make sure you wear safety glasses. It's well worth the time.
Y. Chachad
Quick Reply: hood shocks?
