2007 Toyota Camry official press at NAIAS
SE
XLE
Hybrid
UPDATE: more info.
Press release:
http://pressroom.toyota.com/Releases...T2006010675087
Since press release is huge, here are few selected points:
Better mpg
Bigger wheelbase
Bigger wheels
Bigger brakes
Gone the torsion beam is! :-)
SE is different
XLE is loaded
Option list is nice
Bigger interior
Better Fabrics
Speedo
More Storage
Better HVAC
40% better acceleration with V6
Smooth 6 speed Auto
Sweet Hybrid:
Darn good Cd
XLE
Hybrid
UPDATE: more info.
Press release:
Better mpg
The standard four-cylinder CE model has EPA-estimated city/highway fuel economy ratings of 24/34. Camrys equipped with V6 engines have EPA-estimated fuel economy ratings of 22 mpg city/31 mpg highway, while the Camry hybrid has fuel economy ratings of 43 mpg city/37 mpg highway.
they increased wheelbase (109.3 in., up from 107.1 in.) but maintained the same overall length, with a shortened rear overhang. Even with this lengthened wheelbase, engineers delivered a reduced turning radius.
Gone are the 15-inch wheels previously standard on the LE. For 2007, the CE, LE, XLE and Camry Hybrid will ride on 16-inch wheels of either steel or aluminum, while the sporty SE gets unique aluminum 17-inch wheels with six spokes. These are optimized to help ensure brake-heat dissipation.
Up front, ventilated 11.65-inch discs are used, with solid 11.06-inch discs at the rear. A new brake pad is adopted that provides 10 percent higher coefficient of friction for increased stopping power over the previous model.
Front suspension is via MacPherson struts. At the rear, a dual-link strut system helps provide an optimal balance between smooth ride and secure handling.
The SE has a standard full body kit that positions the car 0.4-inches (10mm) lower than other Camry grades. In addition, a V-shaped brace is added to the SE's body between trunk and cabin and stabilizing braces were added to the underbody to increase the body's torsional rigidity. Finally, to make the SE more appealing to buyers seeking a more dynamic driving experience, the SE delivers performance enhanced by underbody aerodynamics borrowed from Toyota's experience in Formula One.
The XLE's list of standard features includes an upgraded dual-zone automatic climate controlled system with steering-wheel controls, a premium 440-watt JBL audio system with Bluetooth™ technology for hands-free calling, wood-style trim, moonroof, rear reclining seats, fog lamps and 16-inch aluminum wheels. Four-cylinder models are equipped with standard special seat fabric designed to be gentle on the skin, while V6 models feature standard leather-trimmed seats.
Options available on select Camry grades include a tilt/slide moonroof, heated seats, voice-command DVD navigation system, leather-trimmed seating, rear spoiler, Vehicle Stability Control and a Smart Entry and Smart Start system with push-button start that allows drivers to lock, unlock, or start the car just by carrying the Smart Key on his/her person.
Footwell space for the rear seat was enlarged, and additional rear seat legroom was provided. Available rear legroom now measures 38.3 inches, up from 37.8 inches in the previous generation Camry.
So complete was the rethink of the Camry's interior that even the seat fabric was redesigned. Used exclusively on the top-of-the-line XLE four-cylinder model, the new standard fabric is treated by the Fraichir process. In this process, fabric is coated with a naturally occurring component called Sericin, which is extracted from silkworm cocoons and refined. This substance is used because it contains a natural moisturizing component.
The speedometer is marked in five-mph increments, a step that is important to American buyers because speed limits of 55, 65 and 75 mph are very common.
Designers built in many storage spaces around the front-passenger area, including console side-pockets, marking the first use of this storage option in a sedan.
A new HVAC system, standard on the XLE and Hybrid, incorporates automatic climate-control with separate left and right zones. This new system uses Plasmacluster ionizer technology to help reduce airborne mold spores, microbes, fungi, odors, germs and bacteria inside the passenger cabin. The plasmacluster ionizer does this by artificially creating positive and negative ions that seek out and surround harmful airborne substances.
For those looking for more power, the new 2GR-FE engine – a 24-valve, DOHC 3.5L V6 - is available in the LE, SE and XLE. This engine is designed to deliver up to 40 percent better acceleration over the 2006 model year Camry 3.3-liter V6. The V6 is based on bore/stroke measurements of 3.70 x 3.27 inches (94.0 x 83.0 mm) for a displacement of 210.9 ci, or 3,459cc, and uses a compression ratio of 10.8:1 to generate 268 SAE horsepower.
Harnessing this engine's output is an all-new six-speed automatic transmission that uses 21 percent fewer parts than the conventional five-speed automatic transmission it replaces. This new transmission, which can be shifted sequentially, relies upon a newly developed gear train that uses a Ravigneaux-type compound planetary gear for reduced size, weight and friction.
The first half of this system consists of the 2.4L four-cylinder 2AZ-FXE Atkinson-cycle engine, which generates 147 hp and is coupled to a continuously variable transmission (CVT). The second half of the Hybrid Synergy Drive equation consists of a small, specially developed electric drive motor that produces 45 horsepower, an ultra-small inverter with a specially designed compact battery and a transaxle to provide the economy and seamless performance hybrid drivers seek.
Finally, special attention was paid to the vehicle underbody with the use of wheel spats and underbelly pans resulting in a low coefficient of aerodynamic drag (Cd) of 0.27, which helps increase fuel economy.
Press release:
I4: 158 hp, 24/34
V6: 268 hp, 22/31
Hybrid: 192 hp, 43/37
I4: 158 hp, 24/34
V6: 268 hp, 22/31
I like the fact that the bread and butter LE has a power driver seat. That makes things much easier for multiple drivers.
I hate that the CD changer is only 4 disc with the Nav. What up with that? It has alll that new technology, blahblahblah, but they couldn't figure out how to fit a 6 cd changer with the Nav?
Exterior wise, it's okay. Better than the Accord, but I prefer Sonata and Fusion styling.
Interior wise, it's a close second to the Accord. In the XLE, they should have made the wood cover the center console compartment door like they did with the Japanese version. It looks a bit too cold in there with all that fake aluminum in the center and the steering wheel. The shifter area is definitely better than the Accord though.
Hm... no HID option (Altima has those). I was hoping that the XLE would carry them.
It is not an Avalon though, so no xenons or too much wood.
Originally Posted by spwolf
All cd players support MP3's though, so 4 cd's is not that of a problem. Plus, before they used separate cd changer in Toyotas, not in-dash, so it is an improvement.
Most people in this conservative segment are not listening to MP3 cds. They actually (gasp!) buy their CDs and listen to them in their original form.
Anyway, not a huge deal, but a gripe nonetheless. I don't like to have to "downgrade" something to get nav.
What I like the most the new camry is attention to detail - it seems like every single thing has been thought of, and this was not common for an Japanese car just few years ago.
And every part of the car has been improved on. Simply put, everything is significantly better than before. And I bet, pricing will not go up for more than 200$.
A lot more pics:
http://www.thecarlounge.net/gallery/...amry&start=24#
I think SE looks pretty good.
Overall I actually like it. This is one of the first times I'd choose the Carmy over an Accord. I do like the Accord iterior better though. I also dont like the front grill and the rear end, but nearly everything coming out lately the rear end is the weakest part of the car so this isn't really a deal breaker or anything new for me. The one thing I like the best about the stock radio is that it looks like I can take that out and put in an aftermarket unit rather easily.
