Edmunds Tests 2007 ES350
Old 03-20-06, 05:23 PM
GFerg
Speaks French in Russian
GFerg's Avatar
Default Edmunds Tests 2007 ES350
Still not a chromed-up Camry
By Josh Jacquot Email
Date posted: 03-20-2006
Vehicle Tested:
2007 Lexus ES 350 4dr Sedan
MSRP of Test Vehicle: $39,000
What Works:
Emboldened styling, excellent powertrain, more luxury than ever before.
What Needs Work:
Awkward market positioning. Numerous large sedans cost the same or less.
Bottom Line:
It's hard to argue with more luxury and more performance for similar money.
If being noticed is your thing, the 2007 Lexus ES 350 isn't the car for you. It disappears into Southern California's mass of suburbia like a Caprice in Detroit. It's not an image car. So Newport Ned, all blue chips, high horsepower and big ego, won't want one. But his mother, Newport Nancy, probably will. She's more concerned with comfort than visibility, more worried about the way the journey feels than being noticed at the destination. She's practical, enjoys a smooth ride, an agreeable seat, the perfect temperature and easy listening.
If you're anything like Newport Nancy, then Lexus' ES 350 is your car. This Camry-based sedan traditionally combines the practical attributes of its less-expensive sibling with luxury features that make a Lexus a Lexus. The new car continues that convention.
From the outside, the ES 350 is completely updated. Its body has a slicker shape with a longer hood and shorter rear deck. It's a mild departure from the relatively conservative lines we've become used to in the Lexus lineup. Dimensional changes designed to increase usability and performance accompany the new body. There's also a new engine, transmission and multiple safety features designed to keep Nancy as secure as she is comfortable.
Changes for the better
Lexus was smart about increasing the ES's usability without making the car unwieldy. The new car hasn't grown in overall length, but its wheelbase is up 2.2 inches (to 109.3 inches) over the previous ES.
The platform, which is tweaked in size rather than fully redesigned, has reduced overhangs and more space for the doors, which eases ingress and egress. Overall width is up only 0.39 inch while the track width increases by 1.2 inches, producing a proportionally larger footprint. These new dimensions put the ES securely in the realm of other midsize players like the Nissan Maxima, Saab 9-5 and Volvo S80.
Despite the longer wheelbase, Lexus wasn't able to defy physics with the ES. It might be easier to get in and out, but interior space is almost identical to that of the old car. In fact, front legroom is the same as the previous ES and rear legroom is increased only 0.3 inch. It's also heavy. At 3,580 pounds the ES bears no small burden on its powertrain.
New powertrain, better performance
Under the hood there's an updated 3.5-liter V6 good for 272 hp and 254 lb-ft of torque. The dual-overhead-cam design utilizes four valves per cylinder controlled by variable valve timing hardware. This latest version of VVT-i adjusts timing on both the intake and exhaust cams, which increases power and fuel economy while reducing emissions.
There's also a new six-speed automatic transmission which delivers the power to the front wheels and is smaller, using 20 percent fewer parts than the previous five-speed. Shifts can be manually controlled using the sequential-style sport shifter. The tranny also adjusts shifts to account for engine conditions, driving habits and component wear.
In measured testing, the ES's newfound power paid off. Mash the throttle and there's no denying that it has significant thrust for a luxury sedan. Despite its rather hefty curb weight, the ES hit 60 mph in 7.1 seconds and went on to record a quarter-mile time of 15.2 seconds at 94.6 mph. That's only 0.2 second slower than the Acura TL, a decidedly sportier car.
Even during maximum acceleration with the throttle pinned and the tranny fluidly linking gears, you're reminded this is a luxury car. It's exceptionally quiet, engine noise is barely perceptible and there's virtually no road discord. Drive like a normal human being, and you'll be in one of the quietest environments we've tested during a 70-mph cruise (67.5 decibels).
Chassis changes
Little has changed about the fundamental suspension design of the 350 — it still uses struts front and rear. The previous car's Adaptive Variable Suspension option is replaced by conventional dampers tuned to meet a specific comfort/performance trade-off.
It works. On the road, the ES has noticeably better ride control than we expected. Even over small rises at triple-digit speeds it maintains composure. There's a subtle but controlled frequency to its chassis pitch which strikes the precise balance a car in this class should have. It is exactly what it claims to be: a perfect compromise between the couchlike driving experience of an American luxury car and the well-damped ride of a Japanese sport sedan.
Seven-spoke 17-inch wheels come standard with the ES, but our test car was fitted with the optional graphite-finish 10-spokers which come with the ultraluxury package. Each wheel on our test car wore a 215/55-R17 Michelin Energy MXV4 S8 all-season tire. Summer tires are available on the standard wheels.
Through the slalom, the ES's weight was obvious, and body roll was abundant on its way to a 60.9-mph pass. That's slower than most cars its size, but faster than the last Toyota Avalon and Buick Lacrosse we tested.
The ES 350 is fitted with four-wheel disc brakes with ABS and Electronic Brakeforce Distribution. Featuring 11.7-inch front rotors and aluminum rear calipers, the ES brakes hauled the sedan down from 60 mph in 123 feet — a respectable number for a car in this class.
The Lexus cocoon
Inside the ES is a combination of indulgent shapes and textures that are as functional as they are pampering. There's real walnut trim in the center console and door panels, and optionally, on the steering wheel. Leather, which is added with the premium package, is available in three colors: Cashmere, Light Gray or Black.
The ES has perhaps the most functional ventilated seats we've experienced. If you're buying this car for its luxury features, go all the way and get these seats. Their leather is the most flowing, ductile material we've ever experienced in a car seat. Its perforations allow cooling air a direct shot at the target, making them as functional as they sound. Seat heaters were also great at quickly and evenly warming the goods on cool mornings.
Ten-way adjustability makes finding the right driving position easy. But in a car like the ES, it's the details that matter. Our test car was fitted with the power cushion extender which increases or decreases the length of the seat bottom cushion underneath the thighs, allowing support for both long- and short-legged drivers. As if that wasn't enough, the ES can link seat position to two different key fobs. Using this feature, position is automatically adjusted according to which key fob is used to access the car — another example of custom tailoring.
Even with the pamper factor in overdrive, Lexus hasn't lost sight of Camry-like usability and safety. There are eight standard airbags hidden in the cabin plus two optional side airbags for the rear seats. The shifter is a familiar Toyota job that's housed in walnut trim. Gauges are straightforward and easy to read, with an 8,000-rpm tachometer on the left and a 160-mph speedometer on the right. Still, the ES doesn't share a single dash panel or material with its less expensive Toyota sibling.
A new standard
If you ask Newport Ned he'll tell you that Lexus isn't the world's most exciting carmaker. He's right, because the new ES isn't going to blow you away with insane speed or outrageous curves. What it will do, however, is up the ante for other manufacturers competing in the segment. It offers more power, more convenience and more luxury than the car it replaces, and it should have an almost identical base price.
As of this writing Lexus hasn't announced official pricing for the ES 350 although the outgoing ES 330 starts at $32,300. "Expect little change in the base price," said John Hanson, Toyota's national manager of product communications. "There will be higher-priced option packages, however."
An ES 330 equipped similarly to our 2007 Lexus ES 350 test car will set you back $37,925. When the cars arrive in April, we predict you'll be able to get a car like our tester for less than $40,000. And that's about what Nancy wants to spend.
http://www.edmunds.com/insideline/do...ticleId=109687
Old 03-20-06, 05:34 PM
LexFather
Guest
Posts: n/a
Can u say 70k sold. Great work Lexus, 215/55/17 tires, thanks for keeping some sidewall. Seems every car has low profile teeth bumping tires.
Old 03-20-06, 05:35 PM
GFerg
GFerg's Avatar
Old 03-20-06, 06:07 PM
SteVTEC
SteVTEC's Avatar
Now that is a damn nice car. We weren't able to sit in it, but my wife and I took a look at the ES350 (up on a rotating display) and she thought it looked pretty good. It should have a good bit more space than the GS, handling is better than the Avalon, very quiet interior, power is there, Lexus quality, reliability, and refinement. Hmmmmm...
Old 03-20-06, 06:56 PM
rai
rai's Avatar
I just hope it's not overly floaty. I may buy this car for my wife and I'm more interested in the luxury features. But I don't want it to be a boat. I will be driving it also.
It sounds good
Old 03-20-06, 07:21 PM
GStateOM
GStateOM's Avatar
So the Avalon is at least .6 seconds faster to 60? Sort of a surprise, as I didn't it's weight to be that much more significant than that of the Avalon, which is already a large car itself.
The Avalon is around 3700 lbs. in stock form. Wonder what the ES is.
But it looks really nice in these pics. I
Old 03-20-06, 07:27 PM
jrock65
jrock65's Avatar
Exterior is great, better than the GS.
But still can't get over the ***** shaped center stack.
Old 03-20-06, 07:34 PM
AJL0365
AJL0365's Avatar
thought the car may be able to hit the upper 6 second range, but i guess 7.1 isnt bad even though Lexus clocked the ES 330 at 7.2, im sure C&D will push better numbers out. But anyways wish 18' were an option, but 17' are good for a standard wheel size, and the fender flares look really good, and this car looks really HOT in black, very smooth and sophicated looking. a Black ES 350 may be in my future.
At first i didnt like the back of the car all that well, no what i see it in black, i think it looks pretty darn good, at thats just seeing it in pictures, imagine what i would think when i see it in person Lexus did a terrific job on the ES over the years, im glad they didnt give up on it Looks really aggressive from a dead on front shot to
Old 03-20-06, 07:36 PM
Gojirra99
Gojirra99's Avatar
I think we need to see at least a few more test results from various sources to really know how fast the ES350 is compared to the new Avalon. . .
Old 03-20-06, 07:56 PM
AJL0365
AJL0365's Avatar
I wish the taillamps were LED, or something like how the new IS's tails are. If the toyota RAV4 could get LED's im sure the ES could. even the base 4Runner has standard LED tails
Old 03-20-06, 07:58 PM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
Originally Posted by AJL0365
...this car looks really HOT in black, very smooth and sophicated looking. a Black ES 350 may be in my future.
At first i didnt like the back of the car all that well, now that i see it in black, i think it looks pretty darn good, at thats just seeing it in pictures, imagine what i would think when i see it in person...
The black does make the ES look more sleek and aggressive: two words that you wouldn't associate with the ES in general. I'd go for black if I got it...
Old 03-20-06, 08:17 PM
SteVTEC
SteVTEC's Avatar
my thoughts exactly
Old 03-20-06, 09:04 PM
AJL0365
AJL0365's Avatar
just thinking, i was reading edmunds pro's and con's. honestly i dont think they have any con's about the car because they usually type them, something like:
"overally aggressive stablity control system"
"driver seat cushion to short".
their's were:
"Awkward market positioning. Numerous large sedans cost the same or less." I dont think they have any doubts about the ES, and of course thats good and saying alot, especially coming from edmunds.com. im wating to see what the 5 spoke wheel option will look like on this, and i wanna see some chrome wheels on this. put the 18" from the GS on the ES, im sure it would look hot. anyone got a photoshop chopper
Old 03-20-06, 09:15 PM
TheRupp
TheRupp's Avatar
That car looks beyond sleek and classy in black, and I just may be there with ya
Old 03-20-06, 09:24 PM
GFerg
GFerg's Avatar
I'm really liking the Black as well, but I'm waiting for the Flint Mica and White as well. Those are going to look incredible.
Quick Reply: Edmunds Tests 2007 ES350
