Thecarconnection Test Drives the ES350
Old 04-22-06, 08:06 PM
GFerg
Speaks French in Russian
GFerg's Avatar
Default Thecarconnection Test Drives the ES350
2007 Lexus ES350
Relax, it’s an ES350.
by Conor Twomey (2006-04-21)
Sometimes I have to remind myself that not everyone sees cars the same way I do. Many people value comfort and refinement above all else and could care less for steering feel and throttle response. Indeed, it's more than just "some people." There are a LOT of you comfort-loving folk out there and Lexus knows you better than any other carmaker.
While ze Germans continue to assume that everyone in the market for an entry-level prestige model want a cramped sports sedan, Lexus has successfully peddled five generations of ES models as entry-level luxury cars for buyers who want Lexus' legendary quality, refinement, and customer service without the cramped cabins and hard ride of ze likes of BMW, Mercedes, and Audi. As a consequence, almost a fifth of Lexus' 300,000 American customers drove off in a new ES sedan last year and they expect to sell more than 70,000 units of the new model annually. That's not bad business for a prestige car that, ironically enough, is based on the most ubiquitous car platform in America - that of the Toyota Camry.
Still, we can't knock Lexus for giving its customers what they want and to the company's credit, they never describe the ES as a performance car nor do they make any claims about it being a fun drive. In keeping with this refreshingly honest approach, there's no sports suspension option, no manual gearbox, no aluminum pedals. The Lexus ES350 is all about bringing upscale opulence to the entry-level luxury car buyer, however alien the concept might be to me personally.
Handling it up front
So let's get the ugly business of handling out of the way first, shall we? As you might expect, the ES handles with competence and predictability but doesn't really care to involve the driver too much.
The steering is reasonably responsive given the ES's obvious comfort orientation, though there isn't a lot of feel and hard cornering is actively discouraged by lots of body roll and ample tire squeal. Push it too far and the ES breaks away slowly and progressively, and it doesn't take much skill to bring it back on line assuming the electronic driver aids don't get there first.
Not really a car to go attacking canyon roads, then, but even while cruising along at a more leisurely pace I still found the ES a little wanting. The MacPherson-strut front and rear suspensions are a little too soft for their own good, with too much roll and wallow for even the gentlest of country roads, and while the ride quality on the highway is superb the steering doesn't offer enough on-center feel, which means you're constantly making minor adjustments to keep it on track. I've long been of the opinion that sportier cars are a lot less tiring to drive at normal speeds because they're so easy to place and keep on course. The ES might be quiet, refined, and extremely cosseting, but a smidge more feel would actually make it even more relaxing to drive.
Lexus says the 2007 model has been styled using their new L-Finesse design philosophy but it still looks more Toyota than Lexus to my eyes. In profile the ES350 is rather conservative and featureless, which wouldn't be so bad if they hadn't given it such aggressive headlamps, and that scowling expression. The proportions aren't terribly well resolved either, a trait accentuated by the busy design of its small-looking 17-inch wheels, but at least the ES's rear end is appealing and tastefully in keeping with the car's purpose in life.
Inside, the ES finally sheds its Toyota-esque cabin for the full and proper Lexus treatment, with soft touch plastics, wood veneers and quality leather trim on the steering and shift ****. The seats are exceptionally comfortable, too, while rear seat occupants have ample space and a well-shaped rear bench, making it a wonderfully relaxed place for four adults to wile away the hours. Just crank up the optional 14-speaker Mark Levinson stereo and simply let the miles float by.
The cabin's generous proportions are courtesy of the ES's 1.8-inch longer wheelbase and 2.2-inch broader cabin, although it's no longer or taller and barely wider than before. Weight increases by 108 pounds, mostly because of the extra safety gear and equipment, so to counter the ES's ample 3580 pounds, a new 3.5-liter V-6 engine and six-speed automatic are fitted as standard. The 272-hp, 254-lb-ft V-6 is more than up to task of propelling the ES along, whisking it to 60 mph from a rest in just 6.8 seconds while managing an impressive 21 city and 30 highway miles per gallon when driven with less fury.
Thankfully, the six-speed automatic has a manual shift mode so it's possible to manually choose your gear before embarking on any overtaking maneuvers, though the V-6 isn't the most rev-happy engine in the world and once you've made it around that lumbering RV you'll be more than happy to slot the shifter back into D again to quell its muted but noticeable noise. The transmission has also been programmed to hold the car in lower gears when driving uphill or downhill and will even take account of your driving habits, leadfoot.
To prevent people like me trying to drive if off a cliff, the ES350 is fitted with anti-lock brakes, traction, and stability control, which cannot be turned off and doesn't even have a switch to let you wind it back a little but. It's not Lexus' latest VDIM system so the stability control is reactive rather than proactive, meaning the car first has to start getting out of shape before it will react. When it does kick into action, the ES is yanked rather aggressively back into place like a wandering schoolboy, but given how Lexus anticipates the ES to be driven I suppose the use of the older VSC system is hardly surprising.
Should an accident occur, there are twin front airbags, twin knee airbags, curtain airbags, and front side airbags to protect the occupants, as well as an optional pre-collision system and rear side airbags.
Standard specification on all ES350s is generous considering its $33,170 entry-level price. The list includes fog lamps, 17-inch alloy wheels, moonroof, power adjustable steering wheel with audio controls, ten-way power adjustable front seats, ritzy "Optitron" gauges, climate control, keyless entry with push-button start, a self-dimming mirror, a trip computer, and a six-CD changer.
Apart from leather trim and navigation, the swift, spacious, comfortable, and well-specified ES packs just about everything the comfort/luxury buyer could possibly need, which truly makes it a great overall package… provided you don't waving those 3-Series drivers by on challenging stretches of road.
http://www.thecarconnection.com/Vehi...83.A10318.html
Old 04-22-06, 08:07 PM
GFerg
GFerg's Avatar
Old 04-22-06, 08:51 PM
AJL0365
AJL0365's Avatar
even though the wheels are nice i just wish that an 18" wheel was an option atlease, the camry has it, its kinda an aftermarket but its still an option
Old 04-22-06, 09:01 PM
mink92890
mink92890's Avatar
I love the picture with the old ES in the background...
It shows how far lexus has come in a decade.
Mink92890
Old 04-22-06, 09:03 PM
GFerg
GFerg's Avatar
LOL...i like how they used the 92-96 ES300. What about the ES250??!!! Was that model so lackluster everyone forgets about it??!!
Cant even front, I forget that model was produced too. The ES300 is like the first true generation model.
Old 04-22-06, 09:04 PM
LexFather
Guest
Posts: n/a
Mink92890
Me too
Great find Mags!!
Old 04-22-06, 09:05 PM
SC400-V8
SC400-V8's Avatar
kinda intimidating.... the new ES now has acceleration times that match the first-gen SC400s...
Old 04-24-06, 06:41 AM
Lenscap
Lenscap's Avatar
"Inside, the ES finally sheds its Toyota-esque cabin for the full and proper Lexus treatment, with soft touch plastics, wood veneers and quality leather trim on the steering and shift ****."
I disagree with this statement (the "finally" part). Yes, the 2007 has a great interior. But I think Lexus had also successfully given the 2002-06 ES a proper interior that was far nicer and very different from any Toyota.
Old 04-24-06, 07:35 AM
jeffofla
jeffofla's Avatar
I agree. When i was shopping for my 2002 ES, I actually test drove both the Avalon and the Camry. While they used the same chassis, I felt the similarities ended there. It was a big difference even between the Avalon and the ES. I think Lexus has done a good job keeping the Toyota and Lexus brands separate.
Old 04-24-06, 08:13 PM
mhc0725
mhc0725's Avatar
Talking Toyota interior
Totally agree with LensCap and disagree with writer of article that Lexus finally shed it's Toyotaesque interior. I got the chance to drive the 2006 ES330 as a loner recently and almost bought a ES330 had it not been for fact that I found out about an all new ES350 coming out.
I never saw an interior like the ES330 in any Toyota I've ever sat in. Maybe it's just me being biased towards Lexus, as opposed to Toyota, but there is no comparison of the two, although they're owned by the same people. The Lexus leather is richer and more 'buttery" (hate that word actually, but find it used to describe the leather so much) than in a Toyota Camry or Avalon. I'm not positive, but the Lexus leather is probably a finer grade than the ones used in Toyotas.
Short of the power window, and other auxillary buttons, the material inside the Lexus' are far superior in fit, finish, and touch than Toyotas. I think some people confuse "bland" and "vanilla" with being a bad thing. From an enthusiasts standpoint, yes, it's bad. From a car manufacturing and selling standpoint, bland and vanilla sells. Just look at Camry and Accord... always #1 and #2 in sellers. Now look at the enthusiast cars (i.e. Nissan, Mazda), nowhere in sight.
This ES will sell fine and plenty. The top-of-the-line models will probably see a smaller sell, but the lower to mid range models will pick up the slack.
I've actually decided to wait until mid-cycle to see what 'extras' that Lexus will decide to add to the vehicle. I can't see much more being added, except possibly LED tail lights, and maybe some more colors and of course slight redesigns.
Some posted about the photo that showed he second generation ES in the background... honestly, from second generation to current fifth generation, there hasn't been too much overall shape change. They should have put the first generation ES250 (total rebadged Toyota Camry) in the background to illustrate the large change. The ES has pretty much gone in size from the first generation ES250, to the first generation LS400... WOW !!!
Fritz330
01-17-15 08:44 PM
boe
ES - 6th Gen (2013-2018)
12
04-06-13 06:04 AM
carbuff
14
07-26-07 07:53 AM
GFerg
25
09-21-06 06:16 PM
GFerg
04-13-06 10:35 AM
Quick Reply: Thecarconnection Test Drives the ES350
