Lighting mods
Old 07-17-06, 07:04 PM
waynetech2
waynetech2's Avatar
Default Lighting mods
ok peeps, i did this with my poo-poo camera phone, so i apologize..neway ..I changed all my lights to led, installed my illuminated scuffplates, and changed my fogs out.
Allright since its up again I can update. These are the sizes/type of the bulbs:
Low beam headlamp
H11-55W
High beam headlamp
9005
Parking light
168
Front turn signal
992 (7440A)
Rear turn signal
7440
Tail light
LED
Stop light
LED
High mount stop light
LED
Fog/Driving light
9006
License plate
168
Back up light
921
Front sidemarker
194
Rear sidemarker
194
Glove box
37
Front Dome light(3 bulbs inside)
194
Rear Dome light (2 inside)
DE3175 also called "festoon" bulbs
Step/Courtesy light
194
Trunk/Cargo area
DE3022
EDIT: GO TO POST #43 TO FIND AN EASIER WAY TO CHANGE THE MIRROR LIGHTS THAN BELOW!!!!-here- https://www.clublexus.com/forums/sho...6&postcount=43
top right corner screw in pass mirror
the back of the mirror should pop off, i used a credit card to help
the bulb is inside the housing
. just twist and pull out its a reg194 bulb
the finished product
Old 07-17-06, 07:05 PM
waynetech2
waynetech2's Avatar
Default part 2
for the dome lights it easier. for the front dome light there are screws hidden in the sunglass holder
after you take out the 2 screws there are 2 plastic fasteners that hold the rest in. you can pull those out
there are 3 bulbs(194) they will twist out
finished product..you dont see it here but bc the led's are so close to the lens you will actully see 3 bright dots of light within the lens..maybe not if you get refracted led's
Old 07-17-06, 07:06 PM
waynetech2
waynetech2's Avatar
Default part3
the rear dome light is easy just use a special tool called a "credit card" or something like it, and pop off the lens. you will see two bulbs inside. They are called double ended or festoon bulbs or DE3175, 31millimeter(length) bulbs
finished
The LENS in the side doors are red OEM. the new ES350 has clear ones so i bought two of them to swap. THE PART # FOR THEM IS 81230-47010.
1st part of housing
2nd part of housing..it snaps on top of first part.
door light and illuminated scuff plate(i have sports pak so it was PnP)..sorry its blurry
changed fogs..
i think the car looks good at night when i walk up to it and it lights up..YEA!!
Old 07-17-06, 07:19 PM
RyanDe680
RyanDe680's Avatar
Holy crap your headlights are bright.
I see you have silverstar fogs, but what xenon kit do you have?
Old 07-17-06, 07:31 PM
waynetech2
waynetech2's Avatar
ha ha.. na man it must be the camera phone.. i just have oem hid's
Old 07-17-06, 07:37 PM
jasoncd
jasoncd's Avatar
Fantastic! Maybe now I'll finally do some of the bulb changes. Thank you for all the details. Need to stick this in the FAQ.
Old 07-17-06, 07:45 PM
CaThaFeR
speshul c
CaThaFeR's Avatar
wow great info..i think i'm gonna swap out my puddle lamp bulbs too
Old 07-17-06, 07:46 PM
Tony1
Tony1's Avatar
Nice mods, how do you like the LMS exhaust???
Old 07-17-06, 07:52 PM
waynetech2
waynetech2's Avatar
coming soon
Old 07-17-06, 07:58 PM
sab504
sab504's Avatar
Omg sticky! finally someone changing the outside lights. I been tryin figure out how to do it. Thanks alot
edit: damn the screws are pretty tough to get to for those puddle lamps. I feel like I might break it if I push anymore, how did you get to all those screws? did you strain the mirror?
Old 07-17-06, 08:05 PM
javyLSU
2IS OG
javyLSU's Avatar
Great info, and thanks for the pics - I've been meaning to do this for quite some time. Now I have pics to help!
Javier
Old 07-17-06, 08:10 PM
PNice972
PNice972's Avatar
hell yeah! i just ordered 30 dollars worth of led bulbs. im excited to finally change out the puddle lights and inside dome lights. thanks!
Old 07-17-06, 10:16 PM
pocky
mooncake master
pocky's Avatar
Beautiful! So there is technically a way to take out the mirror housing without removing the mirror. Thanks! Oh yeah, Gotta order those clear ES350 door lights.
Old 07-17-06, 10:32 PM
deuce2
deuce2's Avatar
will the puddle lamp still fade in and out after this mod?
Old 07-17-06, 10:38 PM
pocky
mooncake master
pocky's Avatar
LED's should still fade in and out. I have LED's installed on my dome lights, it still fades, but it doesn't wait for "15" seconds to fully dim out.
