winterizing the LS
Old 11-06-06, 02:05 PM
siamiam
siamiam's Avatar
Default winterizing the LS
well its been cold for months up here, it was -18F below earlier today the high should be about 0F but its only -4F right now
does any one know where to order an engine block heater for a 92 LS? no one up here has one
so i have done what i can to it so far, ive changed most of the fluids to winter weight,put cardboard in front of the radiator, ive installed a battery heater,oil pan heater and a transmission heater,I just need that engine block heater. if i have to i might try to install a universal purculater heater.
Alaska sucks
Old 11-11-06, 10:26 PM
siamiam
siamiam's Avatar
any help or information on the engine block heater please?
Old 11-11-06, 11:09 PM
blange400
blange400's Avatar
The fastest thing I found is at www.Jegs.com
Stock #555-51129 40mm Core Plug Heater for Most Toyota Engines
$25
Does that fit the LS block? I dunno~!
Old 11-11-06, 11:12 PM
blange400
blange400's Avatar
Another Idea.....
http://www.jcwhitney.com/autoparts/P...001648/c-10101
Click thumbnails to change view
OIL PAN HEATER KITS
JC Whitney Price: $43.99 - $63.99
Be the first to review this product
Heating pad with self-stick backing installs quickly, easily and permanently to bottom of oil pan—no tools required
Choose from 2 sizes to heat 1-1/2 qt. to 12 qt. oil pans
Warm engine oil in cold weather for faster starts and reduced component wear
End those overnight winter engine start-up problems forever! Simply install the heating pad and plug it into your 120-volt household outlet. Large unit will heat 6 quarts of oil from -40° F to +60° F in about 2 hours. Efficient—use less electricity than block heaters. Kits include thermally-balanced heating pad, 6-ft. power cord, sandpaper, 3 wire ties, squeegee, tube of RTV silicone and instructions.
Old 11-11-06, 11:14 PM
blange400
blange400's Avatar
I would look into a Toyota Tundra Block heater Kit if Lexus-Parts.com doesnt have a special one.
Good luck
Old 11-12-06, 04:17 AM
Kansas
Kansas's Avatar
A block heater for the LS430 is currently shown on the Lexus Canada website -- its installed price is $232 (Canadian). It is quite possible that the same one fits the gen 1 LS400.
I remember verifying that a block heater was available from Lexus when I purchased my first LS in 1990. I was switching from a Mercedes that had a block heater and I really liked having instant heat when I drove out of the garage on cold winter days. But the LS engine warmed up more quickly than the Mercedes so I didn't buy a block heater for the LS.
Try emailing Paul at info@discountlexusparts.com in Victoria, BC (Metro Toyota/Lexus) to see if he can supply a block heater. Metro has an export license, can ship to the U.S. and provides excellent service.
Attached is a photo of the LS430 block heater from www.lexus.ca
Old 11-12-06, 10:56 AM
siamiam
siamiam's Avatar
thank you very much everyone
Old 11-12-06, 03:17 PM
tcho82
tcho82's Avatar
Damn. Alaska must be cold. That's hard core. I think the only thing I've done is make sure my seat heaters work. =)
Oh, and also got the all season tires on.
Old 11-30-06, 11:57 PM
bbct
bbct's Avatar
Default '95-'97 Seat heater elements needed
Speaking of seat heates and winterizing...
Does anyone have an affordable source for 2nd gen LS400 heating elements? My dealer wants $500 for the parts for both front seats.
Old 12-01-06, 10:42 AM
denverdog
denverdog's Avatar
i hate to ask an exceptionally stupid question, but you are using mobil 1 aren't you?
Old 12-03-06, 10:47 AM
siamiam
siamiam's Avatar
im using Amsoil
nippy -17F right now but i hear it might get up to 0F today
Old 12-07-07, 11:45 AM
akxx
akxx's Avatar
If you park outside you may consider a remote start--it's been -20F several times in the winter here (but not as cold continually as where you are!), and remote start fires right up and gets the heat and defrost going by the time I get outside.
Old 12-07-07, 05:22 PM
skperformance
skperformance's Avatar
If your seat heaters do not seem like they are functioning it is a charging issue not eh elements. Change all battery related cables and then the alternator if it persists.
Old 12-08-07, 07:50 PM
Bill Dowd
Bill Dowd's Avatar
Since you are using amsoil your cold start ups will be a lot easier on your engine it will flow down to around 45to 60 below 0, allowing your engine to get oil right now. Amsoil also makes synthetic oil for the transmission that can be used in both the transmission and power steering I would check with amsoil to see if they make the correct rearend oil for your lexus this is a big help in cold weather.You can now buy amsoil products direct from amsoil and have them shipped to your door. Go to www.amsoil.com.
Old 12-09-07, 08:49 AM
sonyman
sonyman's Avatar
I disagree. It's probably the elements. They can stop working over time from stress from sitting on them for so many years. For example, my driver's seat heater barely works, but the passenger seat one keeps its occupant nice and toasty.
Rad1
05-29-19 01:55 PM
westopill
27
11-09-17 12:19 PM
SteveM
12-14-10 03:52 PM
luxury1
12-09-07 01:00 PM
siamiam
22
10-02-06 05:37 AM
Quick Reply: winterizing the LS
