UCF20/21 1995 - 2000 LS400 FaQ(Frequently asked Questions)
Old 02-06-07, 09:37 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
Default UCF20/21 1995 - 2000 LS400 FaQ(Frequently asked Questions)
Here are a few Frequently Asked (and answered) Questions regarding the LS400. Simply click on the links to be taken to another thread with more details. The sections below cover introductory forum rules, links for potential buyers, DIY and FAQ links, lists of threads of common recurring and 'official' topics. Please scroll through and explore!
FORUM RULES AND GENERAL NAVIGATION
Click here to be taken to our forum rules including important details regarding our work safe environment, guidelines against personal attacks, group buy rules and even details on what signature images are allowed (those pictures you see when members post at the bottom of their reply). Please take the time to read them as our forum rules are strictly enforced. If you aren't familiar with forum software, there is also general usage help on how to create and reply to threads, how to update your profile, etc at the end of the FAQ link.
Club Lexus has quite a bit of history on most any topic related to the LS400 model - please look through the FAQ before posting a question. This FAQ tries to capture the most common questions, but please also search before posting if you don't find it here. We're writing a new 'how to' on advanced search but you can get the idea in this post.
Note by moderator RA40: Please PM me or PureDrifter with any potential additions to our LS400 FAQ. Thank you for your help, and support.
Note by moderator timmy0tool: fixed timing belt link for 95-97 Last edit 04.06.2020
Note by moderator timmy0tool: added Unofficial Buyer's Guide Last edit 06.08.2020
Section One - Forum rules and general navigation
Through this FAQ the following terms will be used:
A/S= Air Suspension (factory-oem)
Rear Section= "axle back" ie. using OEM midpipe
Cat-Back= no OEM piping after the Catalytic Converters
*If you post in this thread, it may be edited or even deleted based on relevance or to consolidate information.
ReferenceTutorials
Note: Best place for general information will be www.Lexls.com, most of his tutorials for the 1LS will transfer over with only minor (if any) changes.
Online PartsWhen your car doesn't startRunning issues-DiagnosticsEngine:Cooling System Maintenance:Transmission:Fuel System & Intake:Exhaust:Suspension & Brakes:Wheels:Steering:Body:Interior:Electrical:Lighting:Audio:Modifications:Build Threads:Discussion Threads of Interest:
-OEM Toyota/Lexus wheels that clear 95-00 big brakes (5x114.3, 60.1mm hub)95-00 LS400
01-06 LS430
06-11 ISX50
06-11 GS350/430/460
93-97 Supra Turbo (only)
NO OTHER OEM Lexus wheels will clear.
LS460 wheels do not fit They are 5x120 and will need an adapter.Tire size calculator97 Key programming
'97 Lexus LS400 only
This system is based on the Texas Instruments fixed code transponder. The onboard computer cannot be programmed without a working pre-programmed transponder key. Duplicate keys can be programmed into the system as long as there is at least one working pre-programmed key available. The system can accept a maximum of 6 different keys
Because the coding of the keys is proprietary and is protected by copyright law, cloning is not possible at this time for this system. Until Texas Instruments agrees to license this technology, the only way to program duplicate keys will be by the process outlined below.
Key blanks: Ilco / Silca TOY40BT4, Denso ebay keys available (and work reasonably well!)
Replacement key blanks can be ordered through any Lexus dealer.
Programming Steps:
1. Enter the car and close all doors. Simultaneously depress and release both the brake and accelerator pedals.
2. Within 5 seconds, insert the working pre-programmed key into the ignition and cycle the ignition from the "off" position to the "on" position 5 times. Leave the ignition in the "on" position.
3. Within 15 seconds, open and close the driver’s side door one time.
4. Within 20 seconds, open and close the driver’s side door 5 more times.
5. Within 20 seconds, remove the working key from the ignition.
6. Within 10 seconds, insert the newly cut transponder key into the ignition, and turn the ignition to the "on" position.
7. Leave the new key in the ignition for at least 60 seconds.
8. After 60 seconds the programming should be complete.
9. If you are programming additional keys, insert the next key within 10 seconds of removing the last, and turn the ignition to the "on" position. Once again, leave the key in the “on” position for at least 60 seconds.
10.Start the vehicle to verify that programming has been successful.
98+ Key programming-UCF20/21 Interior Lighting Specifications
2 x #74 for footwells
1 x #74 for ignition cylinder (led will need some sanding to fit right)
1 x #74 for glovebox
4 x #194 for doorlights
4 x #194 for rear maplights(on C pillar)+rear door dome lights
2 x #194 for front corner markers (*921 & 2825 are wattage options)
2 x #194 for rear license plate lights
1 x #194 for trunk interior light (do the neon conversion, MUCH better light output than any 194 bulb or LED)
2 x BA9 for front maplights
2 x BA9 for rear maplights
1 x 31mm dome light
2 x 7440 for Rear Turn Signals
4 x 7443 for Rear Brake Lights
2 x 7440 for Reverse Lights
1998-2000 Specific:
2 x 9005 for High Beams
2 x 9006 for Fog Lights
2 x D2R for Low Beams (HID-Equipped cars only)
2 x 9006 for Low Beams (non-HID cars only)
2 x 7440 for Front Turn Signals
4 x 2825 for Front/Rear Side Markers
1995-1997 Specific:
2 x 9003 for Low Beams
2 x 1156 for Front Turn Signals
Paint Codes
1999 LS 400 Paint Colors
Primary Color number (3digit) is on Driver's door tag/Vin Plate.
First Code is Primary paint code, Second code (5 digits) is the paired Cladding paint code.
051 Diamond White Pearl / UCA29 Warm Silver Metallic
199 Alpine Silver Metallic / UCA75 Gray Silver Metallic
202 Black Onyx / UCA31 Dark Grey Metallic
3M9 Baroque Red Metallic / UCAA7 Dark Rose Red Mica Metallic
4P1 Antique Bronze Mica / UCAA8 Medium Brown Mica Metallic
4P7 Mystic Gold Metallic / UCA77 Beige Metallic
6P7 Silver Jade Pearl / UCAA9 Medium Green Metallic
6Q7 Imperial Jade Mica / UCAB0 Dark Green Mica Metallic
8L4 Atlantis Blue Mica / UCAB1 Medium Blue Metallic
941 Antique Sterling Metallic / UCAB2 Rose Metallic
PARTS
Performance
Exhaust:
  • JIC Twin Spartan SUS (cat- back SS) = MSRP $1,200
  • JIC VIP DE (rear section SS) = MSRP $780
  • 5Zigen Fireball Mega* (rear section SS) = MSRP $750
  • Wald Executive/V2/V3 (rear section SS) = MSRP $1000
  • LSportline Exhaust (rear section SS) = MSRP $1100 (discontinued)
*also known as Border GT
Suspension:
Name MSRP
Spring Rate (F kg/R kg) Drop (F in. /R in.)
Springs:
  • Tanabe DF210 MSRP= $290
    6.3 / 3.0 1.8 / 1.3
  • -H&R Sport Spring MSRP=$389
    NA / NA 1 / 1
  • Eibach Pro Kit = $250 (discontinued)
    NA / NA 1.5/1
  • -LSportline MSRP=$300 (discontinued)
    NA / NA 1.5 / 1
Coilovers:
  • Megan Racing LP Street Series MSRP= $1,050
    12 / 10 na / na
  • BC Racing BR-Type MSRP= $1,250
    12 / 8 na / na
  • Tein Cruising Master Comfort Sport MSRP= $1,400
    NA / NA 2.6 / 2.1 (max dn)
  • JIC FLT-A2 VIP MSRP= $2,080
    14 / 7 ~2.5 / ~3.5
  • Tom's Advox Comfort Series MSRP= $3,000 *discontinued*
    na / na na / na
Air Suspension Systems:Misc. Suspension Braces:
  • Cusco Upper Strut Tower Bar
    MSRP= $150
  • Tanabe Strut Tower Bar*
    MSRP=$98
  • CarsonTuned Billet Rear Member Braces
    MSRP= $130 (not confirmed but SHOULD fit)
  • WIN Strut Tower Bar
    MSRP= $350
  • Tom's Upper Strut Tower Bar(Discontinued)
    MSRP= $300
  • Tom's Front Lower Chassis Brace Kit(Discontinued)
    MSRP= $520
  • Tom's Rear Lower Chassis Brace(Discontinued)
    MSRP= $380
  • Tom's Rear Lower 4pc Link Kit (Discontinued)
    MSRP= $380
*JZA80 Supra TT bar, needs to be bent or use washers to clear for 95-97 cars.
*JZA80 Supra TT (NA will NOT FIT) Bar will fit without modification to a stock '98-00 LS400.
Wheel spacers-adapters:
Custom wheel adapters:Intake:
Air Filter:
  • K&N Filtercharger Air Filter MSRP=$55
    "Wet" oiled cotton gauze
Discovering the rest of Club Lexus
Now that you've explored the LS400 forum, we want to make sure you knew about the rest of Club Lexus and took advantage of all it has to offer. Click the bolded text to visit the mentioned sub-forum.
We've created a new classified advertisement forum specific for the LS and a gallery to host your images, free of charge!
We have a dedicated Automotive Care & Detailing forum that is for discussions on washing, waxing, polishing, detailing, cleaning and maintaining the the beauty of your new Lexus. This forum is moderated by two professional detailers.
Our Vendor Marketplace is the place to find group buys and great deals from ClubLexus' supporting vendors.
The Wheels & Tires Forum is where you can ask all sorts of questions about aftermarket rim and tire combos.
If you want to shoot the breeze about SOB (some other brand) of vehicle, try Car Chat or ask about something else in life try The Clubhouse.
We have many local meets for Lexus enthusiasts, check out the forum for your area.
and this is just a start... we wanted to make sure you took some time to poke around and discover the other areas of the forum that can enhance your Lexus ownership experience. Welcome to our community!
THANK YOU to all the Club Lexus moderators, editors and members that contributed to this FAQ and the linked content!s, editors and members that contributed to this FAQ and the linked content!
PureDrifter is offline
Stormforge
01-29-12 03:10 PM
FAQ & DIY
06-06-11 12:40 PM
FAQ & DIY
NX - 1st Gen (2015-2021)
04-13-01 04:00 AM
FAQ & DIY
RC F (2015-present)
04-13-01 04:00 AM
FAQ & DIY
RC - 1st Gen (2015-present)
04-13-01 04:00 AM
Quick Reply: UCF20/21 1995 - 2000 LS400 FaQ(Frequently asked Questions)
