IS250/350 Brake conversion w/ SS lines.
Old Mar 16, 2007 | 04:38 PM
jet119's Avatar
jet119
Default IS250/350 Brake conversion w/ SS lines.
Hi guys, I just got this mod done, installed front and rear IS350 brake system onto a 250, afterwards took the car to bed in the brakes and WOW...what a huge difference!!! especially with the SS lines and new ATE brake fluid.
The install was straight forward except the rear required some modification to the backing plate for the rotors to fit properly. I took some before and after pics while the car was in the shop getting it done.
here are the rotor size increase between the two,
IS350- Front @ 334 mm and Rear @ 310 mm
IS250- Front @ 296 mm and Rear @ 291 mm
special thanks to parts manager Mr. Lee Moorse at Rallye Lexus.
Before,
Attached Thumbnails IS250/350 Brake conversion w/ SS lines.-350brake-001.jpg
Old Mar 16, 2007 | 04:39 PM
jet119's Avatar
jet119
another before picture,
Attached Thumbnails IS250/350 Brake conversion w/ SS lines.-350brake-003.jpg
Old Mar 16, 2007 | 04:40 PM
jet119's Avatar
jet119
after, L/F corner with wheel on....
Attached Thumbnails IS250/350 Brake conversion w/ SS lines.-350brake-007.jpg
Old Mar 16, 2007 | 04:42 PM
jet119's Avatar
jet119
R/R wheel area, the backing plate had to be modified for the rotor to fit properly.
Attached Thumbnails IS250/350 Brake conversion w/ SS lines.-350brake-009.jpg
Old Mar 16, 2007 | 04:47 PM
t.is350.h's Avatar
t.is350.h
Nice work..Where did you guy get those ss line?
Old Mar 16, 2007 | 04:52 PM
jet119's Avatar
jet119
I got them from Stop Tech... here's a link to the picture i took a while back.
https://www.clublexus.com/forums/sho...t=track+wheels
Old Mar 16, 2007 | 04:59 PM
Dj_AmtraX's Avatar
Dj_AmtraX
How much did the whole kit cost? I can understand why you want the 350 calipers, but I don't see how the lines will make any difference. Please explain.
Old Mar 16, 2007 | 06:44 PM
t.is350.h's Avatar
t.is350.h
I check stoptech and they don't have it.
Old Mar 16, 2007 | 07:20 PM
sinister2c's Avatar
sinister2c
wish i could find some IS350/GS350 brake parts....big bling factor especially behind big wheels.
Old Mar 18, 2007 | 07:13 AM
jet119's Avatar
jet119
Mainly for improved brake feel, steel braided lines does not allow as much line expansion as the rubber hoses does. I did it mainly for trackdays, if i was only going to drive around the streets with it then I wont even bother to change it. stock IS250 brakes are plenty for daily driving.
Old Mar 18, 2007 | 07:16 AM
jet119's Avatar
jet119
here are the part numbers from stoptech.
front 85.523.4500
rear 85.523.5500
i called and placed the order over the phone. maybe it has not been updated at their website yet. hope this helps
Old Mar 18, 2007 | 02:53 PM
ABC's Avatar
ABC
CL Folding 100,000
What was the price on everything? Nice job!
Old Mar 21, 2007 | 01:08 PM
t.is350.h's Avatar
t.is350.h
front 85.523.4500
rear 85.523.5500
Thanks for the info jett
Old Mar 27, 2007 | 11:22 AM
lexem's Avatar
lexem
I had SS brake lines on my last car and I loved it. The braking changed for the better. The peddle felt firm. When applying lots of brake pressure, from about 130mph down to 50mph for a turn the peddle still felt really firm. I can't wait to get these for my IS.
Old Mar 27, 2007 | 11:47 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
FWIW, I checked my TT Supra brake line kit from Goodridge ($89 from Upscale Auto) to see if it will fit the IS350. Not a chance. The rears would work but the fronts are so far off it isn't even a thought.
