BG racing Coilover installed...initial set up and reviews.
Old May 21, 2007 | 04:48 PM
jet119's Avatar
jet119
Default BG racing Coilover installed...initial set up and reviews.
hello everyone, just got these installed on the IS250 RWD with factory sport suspension. it has a 30 way adjustable damper. lowered ride height are 3/4 of an inch from front and rear at 1.5 inch. the car will be corner balanced in a week or two and i'll post final ride height after.
Special thanks to Marc at GT Spec.
http://www.gtspec.com/index.php?nav=home
Initial ride height were as follows:
before:
L/F @ 26.0 in. R/F @ 26 1/4 in.
L/R @ 27 1/4 in. R/R @ 27 1/4 in.
after:
L/F @ 25 1/4 R/F @ 25 1/4
L/R @ 25 3/4 R/R @ 25 3/4
these reading were taken on an alignment rack with all even tire pressures and measured from floor to fenders edge. gas level at 1/8 of a tank. i did not measure from center hub to fender. there're simply way too many factors that can throw this off, i used the alignment rack because its probably the most level surface i can find. also the ride height will always be changing on this car to fit my driving preference so use this as a reference only.
with the damper set in the middle position 15 its no more stiff than the factory suspension. once turned up a few level towards hard setting, rear that is, the car definally rotates alot more but its still manageable with throttle to correct it. so far the rear only has been set to 25 and front at 23 and its quite good for autox with my Advan A048's. in a week a two i'll have the car corner balanced and i'll post up more pics and final ride height.
Attached Thumbnails BG racing Coilover installed...initial set up and reviews.-is250-coilover-001.jpg
Old May 21, 2007 | 04:49 PM
jet119's Avatar
jet119
here are the pictures.....
Attached Thumbnails BG racing Coilover installed...initial set up and reviews.-is250-coilover-002.jpg
Old May 21, 2007 | 04:50 PM
jet119's Avatar
jet119
l/f corner......
Attached Thumbnails BG racing Coilover installed...initial set up and reviews.-is250-coilover-003.jpg
Old May 21, 2007 | 04:51 PM
jet119's Avatar
jet119
r/f area..........
Attached Thumbnails BG racing Coilover installed...initial set up and reviews.-is250-coilover-004.jpg
Old May 21, 2007 | 04:52 PM
jet119's Avatar
jet119
another l/f corner picture.....
Attached Thumbnails BG racing Coilover installed...initial set up and reviews.-is250-coilover-005.jpg
Old May 21, 2007 | 04:53 PM
jet119's Avatar
jet119
L/R corner area............
Attached Thumbnails BG racing Coilover installed...initial set up and reviews.-is250-coilover-006.jpg
Old May 21, 2007 | 04:54 PM
jet119's Avatar
jet119
R/R area..............
Attached Thumbnails BG racing Coilover installed...initial set up and reviews.-is250-coilover-010.jpg
Old May 21, 2007 | 04:55 PM
jet119's Avatar
jet119
coilover installed......
Attached Thumbnails BG racing Coilover installed...initial set up and reviews.-is250-coilover-013.jpg
Old May 21, 2007 | 04:59 PM
waynetech2's Avatar
waynetech2
looking good..now more pics outside
Old May 21, 2007 | 06:44 PM
PNice972's Avatar
PNice972
looks nice, how much and where can i get a set?
Old May 21, 2007 | 08:07 PM
t0e's Avatar
t0e
I noticed the RIGHT side is higher than the left.
This is just so strange. Please let us know how everything measures out, after the "Corner Balance"
Old May 21, 2007 | 11:51 PM
pylee257's Avatar
pylee257
yes please keep us posted
Old May 24, 2007 | 07:39 PM
jet119's Avatar
jet119
will be at englishtown this saturday doing some autox ... i'll have a better idea on how well this set up is afterwards.
Old May 30, 2007 | 07:42 PM
sincityIS's Avatar
sincityIS
How much were those BGs?
Where can I get a set?
Thanks for the help, I am trying to figure out what suspensino to put on my car, but I don't want to break the bank.
Old Jun 4, 2007 | 06:22 PM
sincityIS's Avatar
sincityIS
OK then, nevermind.
