Boosting my 95SC4 and some other projects
#196
Why did you remove the IC???
#197
More boost.
Boost lower in the RPM band.
Much better drivability.
Not really needed with a supercharger anyway.
Less compressor surge.
I could probably think of some more reasons.
After I drive it for at least a few days the way I have it, I will decide wether or not to put it back in. If my intake temps stay reasonable without it, I will have it listed in the classifieds.
With the short drive I took last night, I was only seeing about a 10-15 degree difference between with and without the IC. I don't think losing all the above listed advantages running without it are worth 10-15 degree cooler air.
KC
KC
#198
New vids!!
Couple new vids, must see!
Burnout
http://www.youtube.com/watch?v=VtUWAxegSOw
Massive burnout
http://www.youtube.com/watch?v=4WKS5Vom480
Drive up and drive away
http://www.youtube.com/watch?v=C8SUPEP6bco
Drive by
http://www.youtube.com/watch?v=LiA-6Q8OF1U
Still hope to do some 0-60 runs with the new setup tonight.
KC
Burnout
Massive burnout
Drive by
KC
#199
Burnout
Massive burnout
Drive by
KC
Burnout
Massive burnout
Drive by
KC
Be sure to register online for FI Lexus V8's on Lextreme's site...
Ryan
#203
Some uncut 0-60 runs..
Three runs here. In order, I clocked them at 5.8 seconds, 5.4 seconds, and 5.07 seconds.
http://www.youtube.com/watch?v=RFPTWEXMzvA
Three more runs. I clocked them in order at 6.4 seconds, 5.73 seconds and 4.51 freakin seconds!!!
http://www.youtube.com/watch?v=CO681hcAOag
Notice I tend to get better launching with practice. Keep in mind I am on STOCK size tires, 225 55's I think. I am having a very hard time getting a decent launch without losing traction!
On the bad side. For some reason, I am going way lean with any boost. This is the first time I have had this problem. Made some adjustments to the MAFTPro and hopefully the problem is resolved. I really need to get a rising rate and / or install the injectors I have sitting on the shelf.
KC
KC
#204
KC...these videos are awesome. The car sounds incredible and runs really fast. I definitely concur that an investment in some wider wheels and tires (perhaps even stick 245/50/16's on the stock wheels) would get you off the line with less wheel spin. Obviously, your Torsen LSD is doing its job. The car looks and sounds awesome!
#205
Originally Posted by KC95SC400
Supercharger and all the bits to make it work - $3000 Dragon TQ - $720 MaftPro fuel computer - $400 Torsen LSD - $350 Knowing I can eat most other cars on the road for breakfast - PRICELESS!
#206
Some wider tires will be sometime in the future for sure.
KC
#208
Update and some pics. I know I have too many threads on the same project, I figured I'd keep the pics on this one.
So, as usual, I've been having some issues. I did find out that my EGR blockoff gasket had failed and I fixed that. I figured out that the injector o-rings that seal the injectors into the manifold were leaking, fixed that and decided to go ahead and put in the 315's.
Some pics.
Injectors on the rail with all new orings of course, perfect fit.
Some pics.
