Sewell Lexus Online, lexus-parts.com - Keys, Keys, Keys and more Keys - Promo 909RK
Lexus Key Promotion
Click the chart below to find the available entry keys and use promotional code 909RK during checkout. Should anyone have any questions regarding such keys, feel free to contact us at 888.909.6633, or email us.
Should anyone have any questions or comments regarding the following, we welcome your thoughts. Please contact us during normal business hours, 7 to 7 CST, 888.909.6633.
**Online promotional codes are available for online use only and are not valid via phone or email. If you experience any technical problems with our website and/or any promotional code, please take a moment to give us your error information to us directly at Web Support.
***For those of you who would like to purchase other parts not listed above, don’t forget about the special discount given to all Club Lexus Members by entering CL911M for an additional 10% discount (not valid with any other offer). Each Promotional Code cannot be combined with any other offer.
got this from Cl in another post but should work.
Enter the car with a working pre-programmed key and close all doors.
-Simultaneously depress and release both the brake and the accelerator pedals.
-Within 5 seconds, insert the working pre-programmed key into the
ignition. Do not turn the key.
-Within 15 seconds of inserting the ignition key, depress and release
the accelerator pedal 5 times.
-Within 20 seconds, depress and release the brake pedal 6 times.
-Within 10 seconds, remove the working pre-programmed key from the ignition.
-Within 10 seconds, insert the newly cut transponder key into the ignition.
-Depress and release the accelerator pedal one time. The security
light should now begin flashing to indicate that the computer is
reading the new key and programming the system.
-Leave the new key in the ignition for at least 60 seconds. When the
security light stops flashing, the programming process should be
complete
-Start the vehicle using the new key to verify that programming was successful
complete
The promo code 909RK allows CL members to receive a 21% discount on all the applicable keys shown on the chart above.
When ordering a key, you will be given the option for having your key "cut" or "not cut". There is not an additional charge for such as this is simply a service we provide with our keys.
Upon receipt of your key, you will need to program the key for it to function properly. To program the key you must have your Lexus present at the time of programming AND have at least one of the original master keys.
If you do not possess a master key of any kind, you will need to contact Lexus at 800-25-LEXUS for possible assistance to provide you with additional keys.
Should anyone find themselves in a position in which an engine computer needs to be "flashed" we can too provide this service. When purchasing keys, we do not charge for flashing the computer. By flashing the engine computer, this clears all pre-existing key codes to allow a new code to be saved.
