Air smell..need help..
Old 06-17-08, 11:19 PM
kidluvsole
kidluvsole's Avatar
Default Air smell..need help..
hi, after changing my air cabin filter the air still smell, what can i do to fix the problem?? should i bring it to the dealer is it cover with warranty, it smell real bad the first 3 minutes, i thought because i had dirty air cabin filter, but it wasnt the case, what should i do?? thanks let me know..
Old 06-18-08, 12:25 AM
meefer
meefer's Avatar
You've got MOLD! Probably from moisture off the condenser. THere's a lot of fixes. The ones I vaguely remember are:
1. Run heat full blast for 10 minutes
2. Spray Febreze/oust in the base windshield with the heat on full blast and defrost front?
3. Turn the A/C off 3-5 minutes before you reach your destination.
Combine 1-3 at discretion.
Old 06-18-08, 12:31 AM
geoffers
geoffers's Avatar
As Meefer says, it is mold or a bacteria.
You can buy sanitizers for this. Have the aircon on full, vacate the car and set the can off in one of the footwells.
HERE is one I've used in the past and it worked great.
Old 06-18-08, 12:40 AM
Drunkebuda
Drunkebuda's Avatar
man i been having that smell too...**** i tried the heater method but that didn't work i might try that aircon stuff...man it smells like a clubs bathroom lol kinda like **** i thought it was my cabin air filter too or maybe my intake but it wasn't its MOLD...
Old 06-18-08, 02:17 AM
LEXMAN350
LEXMAN350's Avatar
Take it easy on the beans
Old 06-18-08, 03:12 AM
iKenn
Just call me "Sprinkes"
iKenn's Avatar
hey i noticed my air vents have condensation on them today.
would that mean i would soon get mold sooner or later
Old 06-18-08, 07:21 AM
Yay-Z
Yay-Z's Avatar
Yeah I had this problem as well, complained to lexus about it during my 15,000 mile service and they went ahead and fixed it. No smell now.
Old 06-18-08, 07:57 AM
VikH
VikH's Avatar
meefer is right:
1. Run full heat on HI for a while.
2. Spray Lysol in the vents at the base of windsheild.
Old 06-18-08, 08:22 AM
irv_usc
irv_usc's Avatar
the trick to avoid this problem is flushing out the AC before you shutdown the car.
usually a few miles away i turn off the AC, set the vent to fresh air, and blast on high.
Old 06-18-08, 09:44 AM
jns350
jns350's Avatar
Default here's your solution
Purchase this product or one simular (pepboys or Kragens). You have to locate a drain tube on the underside of your car. You will see it on the passenger side around where the dash area is. Remember under your car. Insert the tube into the drain hose and empty the contents. This will force the solution to fill up the area were the a/c evaporator sits in the blower motor housing. Afterwards remove the tube and let it drain out. Works perfect!!!!
Old 06-18-08, 10:31 AM
VikH
VikH's Avatar
Can you post pics of the location of the drain tube?
Old 06-18-08, 03:34 PM
Drunkebuda
Drunkebuda's Avatar
yah where is the drain tube??? i might have to do that today...i am getting tired of this smell...i tired looking dont see..
Old 06-18-08, 04:44 PM
jns350
jns350's Avatar
O.K. here is where your drain tube is.... First turn your steering wheel all the way to the left...that will kick out the back of your tire(right side/passenger wheel). Then you should already see a black tube about 2-3 in long sticking out from your fender well area again looking at.(right side/passenger wheel). If you look at your wheel as a "clock" then the tube is pointing down fron the fender area at 10 o'clock. That is where your drain tube is. That allows the condensation build up to exit while using your A/C. Very simple!!! ever noticed water dripping from there time to time??? Good Luck... your results should prove favorable!!!!!!
Old 06-19-08, 12:05 AM
Drunkebuda
Drunkebuda's Avatar
thanks jns350 i am gonna go buy a bottle of that thing tommrow and test it out
Old 06-19-08, 05:45 AM
VikH
VikH's Avatar
Good to know. Thanks!
Quick Reply: Air smell..need help..
