Dropped calls with Bluetooth
![Question](https://www.clublexus.com/forums/images/icons/icon5.gif)
OK, so here's the issue that's driving me nuts. Everytime I'm in my car, talking on my cell phone (using bluetooth), and another call comes, if I don't answer that incoming call, both calls are terminated, and the explanation comes up on my Nav screen, "calls terminated by network".
When I'm not in my car, my call waiting feature works perfectly, I can be on a call, answer another incoming call, then go back between calls effortlessly.
Is there any way to adjust the IS's bluetooth features to stop hanging up on all my calls?? Thanks for your help!
what phone are you using? maybe its a program in the phone beacause i know with my old blackberry it did this but when i got a tilt it does not do this and if i want to transfer call then just hit transfer but also might just tell the person hold on and transfer then transfer back...
I've got a Moto Razr V3. I noticed that when another call comes in, my Nav screen doesn't show that I have any options to answer the other call, at least not on the screen. I'm fairly sure that if I took my cell phone out, I could switch between calls, but isn't there a way to do it using the Nav screen/bluetooth to switch between calls?
I used to have this same phone but I never had the problem. I had verizon for my carrier and the phone was purchase new about 2 years ago. My wife has the same phone and it works in the car.
for answering the other call you should just push the talk button on the steering wheel to go to the other line then again to go back.
the transfer call someone mentioned above is NOT to switch over to the other line. that transfers the call to the phone so you are private if you have passengers or you are leaving the car you can continue the call.
Have you also experienced after you leave your car and try to use your phone that you are still connected to your car. So when you try and use your phone there is no sound because your phone has not yet disconnected. ughh....
![Bang Head](https://www.clublexus.com/forums/images/smilies/banghead.gif)
Here is the old thread. PM Bichon and he should be able to help you:
https://www.clublexus.com/forums/sho...light=firmware
![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
why the others are having the call drop I am not sure
thats what the transfer button is for. I have navi so I just go into my phone screen if the navi is displayed and its says transfer or transfer call
that will take care of what you are talking about
I had the same problem when i first got the car and would sit in the car and wait to get out. I just played around with it and it worked
why the others are having the call drop I am not sure![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
AlBoston
07-19-07 12:03 AM
2007, 460, audio, blackberry, bluetooth, bluetoothdropped, call, calls, dropped, dropping, drops, iphone, lexus, network, terminated
