Does your IS250 or Is350 Shakes when idle?
Old 06-18-08, 01:28 PM
trdsw20
trdsw20's Avatar
Default Does your IS250 or Is350 Shakes when idle?
does any of your IS shakes alittle when you stop a red light or unnormal idle? dealer told me is normal.
Old 06-18-08, 01:40 PM
FiveOhNine
FiveOhNine's Avatar
I think the AWD models tend to idle a bit more rough than the rest, but not sure.
Old 06-18-08, 01:43 PM
Evil Teo
Evil Teo's Avatar
i saw a thread on this once and the answer was that it is normal and they explain why. i forgot where but u can do a search.
Old 06-18-08, 02:36 PM
pocky
mooncake master
pocky's Avatar
You mean, does the rpm dip when you come to a stop?
Old 06-18-08, 02:55 PM
kuuqi
kuuqi's Avatar
no i think he means the car physically shaking a bit at idle. i've felt it at times though i wasn't sure if it was the wind blowing hard.
Old 06-18-08, 03:43 PM
slee18
slee18's Avatar
Does it shake all the time? Does it shake hard where the cars rocks side to side?
Sometime the car do shake. The automaker call it a lean-idle misfire. They try to lean out at idle to reduce emissions and save gas at a stop light. My 250 has idled weird twice in the last year. It doesnt happen for a long time tho.
Hope it helps!
Old 06-18-08, 03:48 PM
lexboi250
lexboi250's Avatar
i dont' have the shake issue, but ever since my car is lowered, i feel the vibration a lot more when i'm at a stop light, in drive mode with brake on
Old 06-18-08, 03:55 PM
sdub74
sdub74's Avatar
I've had the RPMs dip and the engine vibrate like it's about to stall. It's happened to me a couple times, always at a red light. I've asked the dealer to check it out a couple times when I was in for service, they came back each time and said they found nothing wrong.
Old 06-18-08, 04:02 PM
Little E
Little E's Avatar
How about this? Check out this thread of mine:
https://www.clublexus.com/forums/sho...+at+Stop+light
Old 06-18-08, 04:20 PM
mikeho
mikeho's Avatar
Yeah, it's happened to me. My friend in the passenger seat noticed it first. Thought it was weird, but I just engaged and released the clutch and the vibration went away. I think you can do the same by putting your transmission into neutral.
Old 06-18-08, 04:54 PM
slee18
slee18's Avatar
once you start driving it goes back to normal. Probably the timing was advanced and then when you stopped it it retarded itself too much.
I have never had it stall like that so that is the bright side.
Old 06-18-08, 05:44 PM
sdub74
sdub74's Avatar
Cool, thanks for the info. I guess if it's normal, I won't worry about it.
Old 12-24-09, 05:34 AM
is250gurl
is250gurl's Avatar
mine has done the same thing to me a handful of times and i'm now at 40k. said something to the dealer yesterday about it when i was in for an oil change since it happened again that morning. they checked the computer for any codes it may have thrown but found nothing. they said i most likely have carbon build up and also need the injectors cleaned. they suggested a throttle body cleaning and injectors cleaned. i say a bunch of b.s.! the car is too young for all of that and i only use premium fuel since i got it brand new. what do you all think?
Old 12-21-13, 12:42 PM
Shervin350
Shervin350's Avatar
Any fix for this?
Old 12-22-13, 07:20 PM
magnuscat
magnuscat's Avatar
Bad gas can also cause this. Ethanol is absolute crap. Swings in temperature can cause condensation which reacts with the crappy ethanol. Ever taken out a gas tank that has been used for a log time with ethanol? Nasty.
Depending on where you live blends can be even worse than other places.
Quick Reply: Does your IS250 or Is350 Shakes when idle?
