FL FS: Headlights, Taillights, Fogs, Stock Arms
I've been holding on to these parts for some reason and need to clean out the garage:
Toyota OEM Halogen Headlights:
Took these off about 2 years ago. They need a cleaning bad. If you have a decent method of polishing headlights these would be a good pickup for a retro. They have been previously opened and the bezels painted with a gunmetal wheel paint. Almost powder coat-looking. No broken tabs or cracks in the housing/lens. They were sealed with clear silicone and will need to be re-opened and cleaned up/polished. The silicone will be a lot easier to open then the stock adhesive.
SOLD
98-00 OEM Taillights:
Drivers side outer tail is cracked in the upper left corner and inners are pink as hell.
$60 shipped
98-05 PSB Steering Rack Bushings:
Got these from Sewell but never got around to putting them in. They sell for $30 with the CL discount plus tax/shipping. http://lexus.sewellparts.com/accesso...1999/4558.html
SOLD
Foglights:
The driver side has a chip/hole in the lens. The hole was already there when I bought the car and I just put a dab of epoxy over it. Never had a problem with moisture or blowing out bulbs. I pulled the epoxy off when I stored them. Lens' are a little pitted. No broken tabs.
SOLD
Stock 99 Upper Control Arms:
Bushings could be shot but they look decent. Balljoint has play but the boot is intact. Could use if you don't want any down time.
SOLD
Stock 99 Trailing Arms:
Once again, the bushings are probably no longer good but they don't look too bad. You can install the Daizen or whatever in these and not have any down time.
$70 shipped
Stock 99 Lower Control Arms:
Bushings look decent but no guarantees. No down time if you want to swap into these then install.
$75 shipped
All prices are to the lower 48 states. Paypal only.
All prices are OBO but don't get crazy. Send me a PM.
Local pickup in Pensacola, FL.
SOLD
$60 shipped
SOLD
Foglights:
SOLD
SOLD
$70 shipped
$75 shipped
Adding another set of headlights. I was keeping these for my retro but I don't see that happening anytime soon.
Toyota OEM Headlights:
These were taken apart and the bezel painted matte aluminum. I was doing the painting in the evening and I apparently can't see too well. The driver side bezel has an imperfection in the primer and it showed through the finish. I planned on sanding and respraying but never got around to it. If you wanted to keep the color, its Krylon Metallic Matte Aluminum and should be available at most hardware stores. The headlights are semi-stuck together since I removed most of the OEM adhesive so I could reseal with silicone. During my move, whatever was left of the OEM adhesive ended up somewhat re-seating but shouldn't be too hard to remove the lense again. The lenses could use a polish but not too badly. No broken tabs or anything.
$150 shipped
$150 shipped
risterdid
Apr 17, 2018 04:22 PM
Kyanite
Jan 24, 2013 08:04 PM
