Cool "hidden" features about the GS that are not very known
Old 07-18-03, 06:59 AM
DrewGS4
DrewGS4's Avatar
Default Cool "Hidden" features about the GS that are not very obvious
Recently someone asked me about some "hidden" options on the GS that is not very evident to all GS owners.
I dug up an old post of mine and summarized the basic points: (other CL members and myself have contributed to this data)
1. Hold the unlock button down for more than 5 seconds and it opens up all the windows and sunroof. This can also be accomplished by putting the key in the keylock and turning the key to the right and holding it there for about 5 seconds.tooopen all windows and left to close all windows and sunroof.
2. Driver and passenger side visor can be turned toward the door window to block light from coming in. But in addition it can be extended an additional 6 inches by pulling it towards you.
3. Steering wheel can be lowered even more by holding the down button for about 6 seconds followed by by a couple more pushes which will bring the steering wheel even lower.
To move the steering wheel and extra 1/2in to 1inch in any directions....click the button 8 times in the direction you want it to move it
4. In the glove box, you can get to the Air conditioner filter and clean it out. You can remove the panel by pulling it straight out and than slide out the A/C filter. I could not believe how dirty and filthy my filter was and I was breathing all that ****** when the AC was on.
5. When giving the car to a valet, you can insert the key into the lock and lock it. But you can also lock it without the key. Just push the lock in and the trunk locks itself. To unlock it you would need to use the key.
6. When you turn the auto button on the AC automatically comes on. If you do not want the AC to come on, than turn off the AC so the green light does not appear when the auto button is on. Next, turn on the off switch to switch off the system. Then instead of hitting the auto switch to activate the hvac controls, hit the fan speed swich left or right button. This will turn on the controls without the AC going on and decreasing the power on tap.
7. You can change the defaut sensitivty of the of the carbon filter from 0 to 3(most sensitive) to turn from fresh air to recirculate. This is in the manual...while the car is running and in park, press and hold down the auto/fresh/auto button until a number pops up in the AC display. Use the AC temperature control button to move it up from 0, 1, 2 or 3.
8. Open the trunk manually with key and the trunk light will not turn on, use the trunk remote on key and the trunk light turns on.
9. To turn of your headlights at night, hit the lock button twice on the remote
10. The last is C-best settings. You can change many things around here by the computer the dealership uses. For instance, I had changed the feature that will allow me to press the unlock key on the remote only once to open all the doors not just the driver door.
See attachment for settings:
For 2001 and up owners see this website for a list of Cbest setting that fits your car:
http://members.bbnow.net/txalec/
File Type: txt
The following 2 users liked this post by DrewGS4:
n1ck (12-03-17), QLex300 (02-09-22)
Old 07-18-03, 07:38 AM
mumbles
mumbles's Avatar
Thanks for the reminder on some of these... I'm gonna have the auto-lock for my doors turned on at my next checkup.
Old 07-18-03, 07:53 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Good post Drew!
11) There are two 'stops' for windshield wipers on the 2nd gen GS, a winter / ice setting and a regular lower setting. If your wipers on on the winter setting they sit way up high on the window and don't tuck behind the cowl. Just push them down hard and they'll 'pop' past the winter stop into the normal one. Looks much better.
12) If you leave your gascap loose, you will get a check engine light after a bit of driving (this is on all newer Lexus). Put the cap back on tight and it should reset after a while. I disconnect the positive ground on the battery for about 5 minutes to do it right away.
Old 07-18-03, 10:13 AM
lexforlife
lexforlife's Avatar
drew
nice post , question though
i see the functions but how do you change the functions like the door lock opener from remote to 2 presses opens up all doors and one press opens just drivers door
how do you change the beep volume coming from the car when you lock and unlock
also how do you program it to unlock the doors when you put it in park
Old 07-18-03, 10:21 AM
DrewGS4
DrewGS4's Avatar
The things you are referring to are called "c-best" settings and only the Lexus dealer can change these particular settings.
Old 07-18-03, 12:38 PM
Belshe1993
Belshe1993's Avatar
Originally posted by lexforlife
drew
To bad we cannot change them ourselves!! That would would be a really wild feature.
Good post.
Oh I checked my air condtioner filter and MAN was it packed with trash.
Thanks again
Old 07-18-03, 01:21 PM
WiLlNyC
WiLlNyC's Avatar
nice post very good info to new or old user...I have a friend that works at lexus as a mechanic i'll ask to see what we can do about the setting.
Old 07-18-03, 01:26 PM
PHML
Master Thread Closer!!
PHML's Avatar
Excellent info.....thanks for sharing.
Old 07-18-03, 02:43 PM
Nexusbeta
Nexusbeta's Avatar
thanks for the post drew now to go to the garage and test them hehe
Old 07-19-03, 12:14 AM
GSquicksilver
GSquicksilver's Avatar
DREW,
I tried #9 but it doesn't work. Any insight?
Old 07-19-03, 12:15 AM
GSquicksilver
oh yeah, what happened to my signature?
Old 07-19-03, 07:27 PM
tinygs
tinygs's Avatar
Originally posted by DaveGS4
Good post Drew!
Is #11 sure thing??? I will be trying this asap......
Old 07-19-03, 09:39 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Absolutely is. Compare yours to another GS and if yours are in the winter position, you'll definitely see the difference. It's very apparent; I noticed it on TomTNC's GS not long ago and told him about it. His fiancee (now wife) said "that's the best modification I've seen so far... FREE!"
Old 07-20-03, 04:42 AM
Hameed
EV ftw!!!
Hameed's Avatar
Originally posted by GSquicksilver
DREW,
It definitely does work. I use this feature all the time. A very simple test is this. Leave your lights on, turn off the car and then go out and hit the lock button twice and the lights go off on the second click of the lock button.
Old 07-20-03, 04:44 AM
Hameed
EV ftw!!!
Hameed's Avatar
Default Re: Cool "Hidden" features about the GS that are not very obvious
I cannot find this panel. Can you please give some more direction on where this is? Is it behind the CD changer, or beneath it?
Quick Reply: Cool "hidden" features about the GS that are not very known
