phillips 6000k vs acura tl-s HID
A while back, there was some debate about the TL type s and its HID color. I got a hold of a TL HID bulb and put it in my GS to compare the color with my Phillips 6000K. Here are the pics. I did do a white balance, so the pics are as close to accurate as possible.
hope this sheds some light on the debate
ricky
ricky
Someone that manufactured the HID aftermarket kit once told me that the color spectrum of the light emitted by the HID's is dependent on the projector lens of the headlight. If that is true, then it is possible that the TL-S projector lamp creates a whiter spectrum and you can't necessarily compare just the bulbs.
I am jumping midstream into this topic so I don't know if this debate was started because of the fact that the HID on the TL-S is yellower than the philips HID kit and I wouldn't know. Oh well...
Brent
Brent
Brent
Brent
I think what ricky has done here is an acceptable test respresenting the different color temps since both the GS and TL HID systems are both of the "reflector" type.
Not trying to play the role of lex400sc, who I consider the lighting guru or anything, just relaying what I've picked up here about HID systems.
Just my 2 cents into this hid topic......... Eropean Projector lighting i.e. bmw, audi, mercedes all utilize sharp cut off on thier beam pattern. This is what gives that alluring puprlelish/bluish change of color when you see these OEM headlight head on. That effect essentially is the prism effect of the lens on the projectors. Our headlights are just free-form reflectors. What our HID burners put out.... is the color we get. By the way..... Philips 6000K ultinons are the best kelvin temperature color for our cars...... I've personally seen 4100K, 4300K, 5500K, 6000K, 7000K, and 8000K. 6000K are the only hids that look like true OEM HID with the tinge of blue. All the others can easily be mistaken for cheap colored bulbs..... Beware... there are tons of companie out there on the net and Ebay claiming thier kits are Philips 6000K ultinons. What you really get is a cheap Korean or Taiwanese kit.
