power window failure
Old 06-26-03, 12:34 PM
russ29
russ29's Avatar
Unhappy power window failure
I have a 99 GS300 and the left rear door power window does not operate. It will not work from the fob, driver's door switch or passenger's door switch. All other windows and sun roof operate fine...
Is the a common problem?
Old 06-26-03, 02:06 PM
Tranman
Registered User
Tranman's Avatar
Hmmm, in my experience...in most cars, when a particular window does not work, the switch at that window is usually the culprit...check to see if the switch works on the driver's rear door.
matts6887
12-16-18 10:26 AM
Mr177
09-04-18 10:32 AM
PanicUnit
Maintenance
08-20-10 08:23 AM
02lex300
06-10-10 05:14 PM
Quick Reply: power window failure
