At 9K miles inside of tires worn !! I did not rotate though..
I just had an oil change, and my freakin inside edge of my front tires are bald......what up with that ? I may be to blame for this, I had asked the last two times to NOT have my tires rotated. My first IS 300.....the dinged and scrapped the rims...
Lexus of Portland sucks on an imeasurable level !
I can't fight this with warranty.....sucks
If you ***** they will give you a new set of tires. Is300 have a lot of problems with the alignment. And the tires are ****ty. Bring this matter to the GM of the dealer, he will take care of you. I work at a Lexus dealership, So i know.
JPI
JPI
Originally posted by lexusnexus
no suspension work, stock tires.....nobody at Lexus said rotate or you'll have bald tires..should I approach the GM ? Or will he be lame ?
......brand new, 24 miles on it when I bought it
Good luck.
Re: At 9K miles inside of tires worn !! I did not rotate though..
The dinged rimes are another story. If the dealership was at fault, they should definitey remedy the situation. Good luck.
Here is the deal:
IYou should have rotated the the tires around 4000-5000 miles, but the camber is out on your IS if the insides of the tires are bald. The warranty is covered under warranty up to 12,000 miles if you have not lowered or has different wheels. Go to a local shop(that is reputable) and ask them to check your alingment and get them to print out the alingment specs and I'll guarantee that the camber is out. :-)
