Transmission Cooler
Transmission Cooler
hi, does anybody installed an auxillary transmission cooler like hayden or B&W, or derale, so instead of running out of the radiator, this now to be rerouted to the cooler, any thoughts
Super Moderator
The guys in the GS forum have discussed this to some length. What I recollect is that for normal conditions, the factory set-up is more than adequate to handle the tranny heat. If you install a TC, tow or drive the car hard in a hot climate then you may see some benefits with a cooler.
Many cars are tested in Dealth Valley during development so for the most part, it is fine. If you are having tranny fluid issues or related heat problems, there is likely something wrong in the system that needs attention.
hi, i installed a B&M supercooler part#70264 couple of weeks ago, went smoothly, infront of the radiator right side if your facing the car, along with these i replaced the filter, clean out the shift solenoids, installed a new gasket, then on with the tranny flush, after 7 quarts got all new fluid in the tranny (red T IV), after all is said and done test drive it ohh what a difference, no more the once in a while jerk you experienced id say a
