SC- 1st Gen (1992-2000)
update on my car
Old 07-08-05 | 04:02 PM
nism0's Avatar
nism0
Default update on my car
Edit: More pics on page 2
Picking up the car from the body shop tomorrow, but here are just some pics of it now. I will get more up tomorrow. The whole car was repainted black. Can't decide if I should put the emblems back on.
Also found out that the wheel has broken the inner fender liner on the driver side and is ripping at the harness. it has actually cut one of the wires. So i gotta do someting about that now. But I don't want to raise the car.
I'm getting a 1JZ within the next couple of weeks, but I can't find a shop that I can trust to do the swap. I might e
nd up doing it myself with some friends.
Old 07-08-05 | 04:06 PM
RaynArt's Avatar
RaynArt
looks awsome, what suspension setup do you have? as for the emblems i think at least just the rear "L" and "lexus" ones, forget the scX00.
Old 07-08-05 | 04:23 PM
MrJohnTan's Avatar
MrJohnTan
Remove the fender, reroute the harnesses to go over the top of the fenderwell, zip ties, hammer out the metal edges inside the fenderwell, replace fender.
In a few hours.. problem solved... my car was lower than yours =)
If for some reason you plan on bringing your car to socal check out www.srmotorcars.com theyve done several swaps and dont charge an arm and a leg like most of the other shops.
oh yeah.. keep the emblems off.
Old 07-08-05 | 05:07 PM
nism0's Avatar
nism0
hks hipermax II coilovers.
do i have to lengthen the harness or cut it? Or do i just pull it over the top of the fender wheel.
thanks.
Old 07-08-05 | 05:13 PM
MrJohnTan's Avatar
MrJohnTan
thanks.
harness is long enough. if you want to be super duper clean, cut a notch in the wheelwell to route the harness from the inside the fender to the top of the wheelwell, then another notch to route the harness back into the engine bay. for sure you gotta remove the plastic crap holding the harness together tho.
Old 07-08-05 | 06:08 PM
Din's Avatar
Din
i should do this.
Old 07-08-05 | 06:20 PM
burburlulu's Avatar
burburlulu
Put the JDM Soarer Lion emblem
Old 07-08-05 | 06:37 PM
plex's Avatar
plex
1UZFE/2JZGTE
What front lip is that any clearer pics?
Old 07-08-05 | 06:51 PM
dinh626's Avatar
dinh626
I"m pretty sure it's stock, just painted the same color as the car.
Old 07-08-05 | 08:32 PM
happypanda's Avatar
happypanda
how much u paid for the paintjob?
Old 07-08-05 | 09:30 PM
plex's Avatar
plex
1UZFE/2JZGTE
yea so it seems i must be getting sleepy
Old 07-08-05 | 09:36 PM
ACleanSC4's Avatar
ACleanSC4
the Griffin
Old 07-08-05 | 11:36 PM
nism0's Avatar
nism0
it's the stock sc400 lip painted the same color as the car.
the car was in an accident about 3 weeks ago and it was about $1500 to fix the car and an extra $500 to repaint the whole car.
Old 07-09-05 | 12:08 AM
MrJohnTan's Avatar
MrJohnTan
Originally Posted by ACleanSC4
the Griffin
get it right dude....
Old 07-09-05 | 06:32 AM
mteele's Avatar
mteele
CL Folding 10,000
looks a lot like ki_soarer's car. drive down here, im sure he will do the swap for a good price.
Quick Reply: update on my car
