CA Need a 2jzge engine 1994 GS300!
Old 07-18-09, 09:39 PM
henry89trd
henry89trd's Avatar
Default Need a 2jzge engine 1994 GS300!
Hello guys I posted some time ago that I wanted to buy an engine for a 1994 gs300, and asked for ideas an what to do, thank you all for your suggestions. Most of you recomended swaping out the non turbo 2jz motor to a turbo one and you guys also said that it would cost about 2-3 thousand for the whole thing. I was gonna save and I know that would be good, but I just need a car, I wanted to see if anybody has or knows where to get a motor or if anybody knows where they sell good jdm imported engines in the Los Angeles area!! I have no wheels right now and would rather fix my gs300, than try to get another car, If anyone can help that would be AWSOME!!!
henry89trd is offline
Old 07-18-09, 09:43 PM
henry89trd
henry89trd's Avatar
I know that there are companies that import motors from japan, they clean them up, test them and guarantee them for like six months or something. If anybody know of a place like that, please give me there #, THANK YOU GUYS!!!
Old 07-20-09, 11:41 AM
moejz
moejz's Avatar
If you are looking for a 2jzge engine, I have a good running one I just pulled out of my 2jzge from my 95GS300. Only reason I pulled it because I went to a full 2jzge setup.
Engine in excellent condition with a recent timing belt change etc.Was well maintained and I bought the car from a older couple so i know it was not beat down on.
No leaks or smoke or anything of that sort. I can let the engine and transmission go for $500. You can drive a small truck to Norcal and pick it up yourself and it probably won't cost you more than $200 for the trip and you can do it in one weekend.
I will throw in the newer radiator the previous owner put on it as well.
Upside of buying from me ?
I know these engines pretty good and I maintain my cars well.
I know its a good running engine because I just removed it 2 weeks ago.
Its very clean ( I washed it when I first got it) - that is how I know there is no leaks.
At least you know it was not sitting outside in a wrecking yard before being shipped over to us.
Everything comes with it except for wiring harness and ecu and the tranny cross member. motor mount bracket with one good mount is inlcuded as well.
If you want me to replace any seals/hoses etc, I can do it for you for free as long as you pay for the part.
I have good seller rating on here and a lot more on Supraforums.com. ( Suprastanger507mgte )
Let me know..
Moe
moejz is offline
Old 07-21-09, 03:03 PM
GS300916
GS300916's Avatar
Whats the mileage on the motor your offering?
GS300916 is offline
Old 07-21-09, 10:02 PM
moejz
moejz's Avatar
I pulled it out at 180k . Ran super smooth and super quiet. Just like a Lexus should.
moejz is offline
Old 07-21-09, 11:32 PM
henry89trd
henry89trd's Avatar
Hey guys I have a question, someone offered me a 1993 sc300 engine, Its a 2jzge and it looks just like the gs300 motor, The question is, Does it Fit the 1994 GS300?
Old 07-21-09, 11:49 PM
moejz
moejz's Avatar
you will need to source a front sump oil pan . If you r car has an engine, you can transfer the oil pans ( upper/lower) and the oil pickup and baffle all of it to the engine.
You may also have to swap out the motor mounts...but not sure about that. most likely though.
moejz is offline
Old 07-23-09, 11:42 PM
GS300916
GS300916's Avatar
I have a sc motor in mines from a 97. We swapped the oil pan as well as the intake manifold, exhaust manifold and everything else but the head and block.
GS300916 is offline
Old 07-25-09, 10:33 PM
henry89trd
henry89trd's Avatar
Thanks for the advice guys, I found a real good motor with only 60,000 mile that came off of a 95 sc300. My friend Harvy is dong the swap for me and so far he took the old motor out and is swapping the oil pan. He told me the internals of the new engine are really clean. Thank for all your help guys!!!
Old 07-29-09, 05:10 PM
henry89trd
henry89trd's Avatar
One more question. The mechanic is telling me to find out if there is a gasket for the sump oil pan. I whent to autozone and the dont have anything. I know theres a gasket for the oil pan, but is there one for the front sump oil pan or is it just siliconed??
Old 07-29-09, 09:12 PM
moejz
moejz's Avatar
No there isn't any gasket. You will need to buy the FIPG from Toyota or just get the Grey Gasket maker ( FIPG) from Autozone or some place similar.
moejz is offline
Old 07-29-09, 11:17 PM
henry89trd
henry89trd's Avatar
THanks for the advice
Old 07-29-09, 11:21 PM
henry89trd
henry89trd's Avatar
Here I am again asking for advice and help. I spoke with my friend whos swapping the motor and he was under the car today and told me the car was hit, but it wasnt major. All I have to do is change (I AM NOT SURE AND NEITHER WAS HIM)
Old 07-29-09, 11:24 PM
henry89trd
henry89trd's Avatar
but I thinkits called the rear left side trailling arm, or stabilizing arm. If anybody know someone thats parting out a 94 gs, please let me know. They look like two long bars that have bushing at both ends, it bent. Thank you guys.
Old 08-11-09, 06:59 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
hey, sorry to hijack but interested in selling me the front sump off that SC motor? i might have a use for it.
PM me. thanks!
PureDrifter is offline
Quick Reply: CA Need a 2jzge engine 1994 GS300!
