CAN-Vancouver Sage Front RCA 30mm & 18mm
I'm selling a set of RCAs I recently purchased. I no longer need them as I decided to go another route. I have a pair of 30mm and 18mm but I cannot part them out as I only have one set of bolts and washers. You will need these to install the LS400 calipers. Use the 30mm if you want a larger drop or use the 18mm if you want the minimum amount to clear the LS400 calipers. The 18mm ones are prototypes and require a a bit of modification to make fit but the 30mm are good to go.
SOLD!!!
SOLD!!!
![](http://photoshare.shaw.ca/image/7/e/a/234510/photo-0.jpg)
SprtDesign
04-07-14 09:42 AM
Sonic_RC
12-17-11 11:37 PM
