FS - Teck Grounding Kit for IS300
$40 Shipped (payment via PayPal)
Teck Grounding Kit for IS300 - Used
Silver Wiring
Black Ends
Silver Terminals
http://www.teckkits.com/
Silver Wiring
Black Ends
Silver Terminals
The Lexus IS300 kit is composed of an 8-wire setup that grounds 8 points in the engine bay. Included with the kit are instructions, 4 small extended bolts (3 used and one extra in case you drop it into the engine bay while installing), 1 large bolt, necessary washers / lock washers, and 5 tie wraps. Kit comes complete with all necessary hardware and accessories to install. The only tool needed is a socket wrench set with 10mm, 12mm and 13mm sockets. Typical installation time is 30-60 minutes.
Improvements are seen in both Manual and E-Shift models. The kit noticeably increases engine startup, efficiency, smoothness at idle and throughout the powerband, throttle response, shifting, and overall drivability. The most drastic change being shifting and throttle response. E-shift owners agree that the grounding kit dramatically reduces shift lag that is a common trait in those models. Manual owners also improve shifting through better throttle response, making it easier to match engine speed when changing gears. Overall, the IS300 becomes more refined… the way it should have come from the factory.
Boost your vehicles electrical system with a custom Teck Grounding Kit™. These kits provide a direct ground path from the negative battery terminal to the vehicles unibody, engine components, and critical electrical components. Upgrading your electrical system for improved idle stability, throttle response, shifting, and drivability.
Each kit is custom tailored to the specific application, avoiding the unsightly wire runs of nonspecific kits, all while tastefully dressing up the engine bay. Only the highest quality components are used in the construction of each wire. By utilizing your choice of gold or silver plated terminals, 4 gauge 1666 high strand count OFC (Oxygen Free Copper) wire jacketed in high quality PVC insulation that is impervious to oils and high temperatures, these kits offer superior conductivity and quality.
LiCelsior
03-25-10 05:48 AM
canter
09-06-05 01:48 PM
