F/S Stoptech Stage II Drilled Brake kit
To be quite honest, I don't come to clublexus as much. I am known on is300.net and I visit that more often on a regular basis. I am just wondering if anyone would be interested in this brake package. I have a strong rep over at is300.net
I just messed up.
I ordered the stage II kit but accidentally marked drilled and slotted and I don't want 2 kits.
I just paid 691.00 for it but willing to let them go for 660.00 shipped because of my mistake. Savings of $31 dollars directly from stoptech and around $15 dollars cheaper than PLP.
It's a brand new drilled rotor stage 2 kit and will be shipped directly from stoptech.
StopTech's SportStop slotted or drilled rotors, StopTech stainless steel brake lines, street performance pads and 3 bottles of Motul RBF600 brake fluid. Rotors, lines and pads are for both front and rear. Components can also be purchased separately. FITS STOCK CALIPERS.
Slotted or drilled rotors prevent glazing of the pads, add bite and improve wet and dry braking performance. StopTech's SportStop rotors have a durable black coating on the non-swept areas of the rotor to prevent unsightly corrosion, and quality is assured as the rotors are manufactured to meet or exceed all OE specifications. Stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow. High performance street pads provide you with higher resistance to fade, higher maximum operating temperature, and better initial bite to allow consistent deep braking into corners. Motul RBF600 brake fluid increases both wet and dry boiling points and prevents boiling even under the most severe operating conditions. Good for street and autocross. Not for extended track sessions.
http://stoptech.com/products/stage1_2_upgrades.shtml
PM for paypal address.
I just messed up.
New CL Vendor Futura Design Big Brake Kits for 2IS
Futura Design Brakes
CL Vendor Products for 2IS
08-19-15 07:47 PM
alphais300
06-18-10 10:03 AM
