2jz-ge Valve Covers and Timing Covers Powder Coated / Painted w/PPG paint
Valve covers - 60 shipped
I have a set of non-turbo 2j valve covers that I had powder coated a metallic grey. I did not grind off the casting flash before I had the covers coated so you can still see a bit of it. I got a good deal on a set of GTE covers so these are no longer needed.
Timing Covers - 60 shipped
The PCV holes have been tapped for a 3/8 NPT fitting and the areas under the splash plates were removed so I could clean them out. Plates have been re-installed and re-sealed. I have one fitting that will be included with the valve covers. It will probably run you $10 for another one at a plumbing supply store or you can get a couple of Earls PN 984208 fittings for about $40 shipped from www.anplumbing.com or summit, ebay etc.
Also for sale is both pieces of the #3 timing belt cover. This is from a lexus and it has been painted with PPG DBC and clear - not some cheap Omni stuff. The back cover was modified before it was painted to allow room for the use of some GTE coil on plug packs. You can see some small dirt flecks in the clear but the paint is nice and glossy. It really does look nice. Good paint used. It is a honda-metallic black and gives off a nice gleam in the sunlight. The Lexus emblem is shiny....
If somebody wants to buy these as a set I will send them out for $100
email cade_peterson@hotmail.com for pics - I have an upload limitation here. Or check here for pics:
Pics
Pics
