BOOMSLANG harness for EMU 01 auto
I have a 2 month old plug and play harness made by boomslang for the emanage ultimate. This harness is for a 01 automatic, this is a full plug and play harness. I got this with a turbo kit I purchased and I have 03 5speed.
$200 shipped including paypal fees!
Here is the actual discription from boomslang:
You will wish that all the modifications you make will be this easy. This product will allow you to connect GReddy"s popular eManage unit with out any cutting or splicing of your factory harness.
To install, you simply unplug your factory ecu, and plug the PnP harness between the ECU and the factory wiring. Connect the emanage to the other end of the harness, and you"re done. How easy was that?
All harnesses come prewired for injector (fuel), ignition (timing) and the main harness. You do not need to purchase any additional harnesses from GReddy, unless you want to run the pressure sensor.
You can check my itrader from .net as this is my first post here. Same name there.
deputy865
SC400 / 300 Classifieds
15
01-19-13 09:20 AM
