NY FS: Complete PLP PowerDyne Supercharger kit
asking for $2100
Pictures coming later today.
I purchased this kit from the original owner who had it on for about 20k. He sent it out to get rebuilt 6k miles ago by 928motorsports.com. 928 specializes in BD11 supercharger units. I am selling my IS300 so this kit is no use to me. I never had the opportunity to install this; being that I have two jobs and a full time student.
The ABS and Supercharger bracket were sand-blasted and awaiting paint or a clear coat (whichever you perfer).
Additional Parts:
Autometer Boost Gauge
7th ~ 750CC RC injector (mounted)
550CC RC injector
450CC RC injector
255 Fuel pump
E-manage Blue is tuned for a 5spd IS300
This Kit is Plug and Play. No additional parts are needed to install this kit.
Manufacturers Description ~
http://prolexperformance.com/asp/product.asp?id=2
7psi Supercharger Kit
After months of extensive research, design and testing, PLP is proud to announce the completion of the Lexus IS300/GS300 BD-11 series supercharger system. The system features a additional fuel injector and a Greddy engine management system for outstanding horsepower and torque gains and civility for everyday driving. The PLP BD-11 Supercharger kit features wrinkle black powder coating to maintain the factory appearance.
At the heart of the system is the Powerdyne BD-11 unit featuring a patented SilentDrive cog-belt internal drive assuring high speed performance at all RPM’s along with outstanding reliability and quite operation. With no drive gears to lubricate, SilentDrive eliminates the need to route oil from the engine. The absence of hot engine oil allows Pro Lex Performance supercharger system to run cooler, thus reducing under-hood temperatures while providing a denser air/fuel charge for increased efficiency and maximum horsepower output. Features a supplemental injector that adds more fuel directly into the inlet of the throttle body providing a intercooling effect for increased power and torque, this also simplifies the installation and maintains stock drivabilty Greddy management system and software stands in command of the fuel and ignition system. The system comes un-tuned and tuning is the responsibility of the customer, tuning for each specific installation will yield greater horsepower and torque.
The BD-11 unit also delivers substantial power increases over conventional centrifugal superchargers due to the unique Hyperdyne impeller. This airfoil shape and computer matched scroll combination provides more pressure and flow at comparable RPM’s than the competition for superior boost and low-end torque. The result is better acceleration and more power throughout the RPM range.
The drivability is maintained 100%, the horsepower and torque delivery as well as the automatic transmission shifting is as smooth as silk. The vacuum bypass system remains closed when you need the power. When you are simply driving, the bypass opens to reduce the load on the supercharger. The transition is also smooth and seamless.
This system maintains all OBD-II functions and is 100% maintenance free. The Powerdyne Supercharger is backed by a comprehensive 2 year limited warranty**. The system installs 8 hours using normal hand tools and no irreversible modifications to the car is necessary.
Horsepower and Torque Gains
* Peak Horsepower: 321 hp @ 6400 rpm **** BD-11 7psi.
* Peak Horsepower Gain: 119HP @ 6400 rpm **** (2001 IS300 7 PSI Kit).
* Peak Torque: 278 lb/ft @ 5600 rpm **** BD-11 7psi.
* Peak Torque Gain: 115 lb/ft @ 6400 rpm **** (2001 IS300 7 PSI Kit).
Kit Components
* Powerdyne BD-11 (Super Drive) supercharger unit.
* Greddy Emanage, boost sensor w/ harness, injector harness, ignition harness.
* Additional fuel injector.
* 6 NGK spark plugs.
* Intake tube assembly finished in PLP exclusive black hammer tone powder coat w/ fiberglass reinforced silicone sleeve connections and stainless steel hose clamps.
* PLP high flow filter element.
* Discharge tube assembly manufactured in 6061 aluminum with bead rolled ends finished in PLP exclusive black hammer tone powder coat w/silicone sleeve connections and stainless steel hose clamps.
* Throttle body fiberglass reinforced silicone sleeve w/stainless steel hose clamps.
* Bosch by-pass air diverter valve.
* 1.0" by-pass hose.
* Vacuum line w/tee connector for by-pass.
* Heavy duty drive belt system.
* Idler pulley w/retainer & spacer.
* Blower main bracket assembly.
* ABS control unit bracket and hardware.
* 2 Year limited warranty **.
* 100% Maintenance free operation.
* 100% Bolt-on installation.
* Tuning Software and Cable Required
Powerdyne Properties
* Hyperdyne™ Impeller
Powerdyne delivers substantial power increases over conventional centrifugal superchargers due to the unique Hyperdyne™ impeller. Featuring an exclusive curved-blade design that literally grabs air at low speeds, the Hyperdyne™ impeller generates low RPM boost levels that are unmatched by the competition. The airfoil shape and computermatched scroll combination provides more pressure and flow at comparable RPMs than any other centrifugal supercharger on the market.
* SilentDrive™ Belt Drive
The same technology that drives the huge blowers on Top Fuel Dragsters and Funny Cars has been refined by Powerdyne to produce the only belt-driven centrifugal supercharger manufactured today. Utilizing the latest reinforced belts and precision machined drive pulleys, the patented SilentDrive™ system eliminates the annoying rattles, chattering, whine and reliability problems encountered with conventional gear-driven. superchargers. The Powerdyne Supercharger is the quietest centrifugal supercharger on the market today.
* No Oil Lines! No Oil Reservoir!
With no drive gears to lubricate, SilentDrive™ eliminates the need to route oil from the engine or a separate tank to the supercharger, which vastly simplifies installation.
Additional Parts:
550CC RC injector
450CC RC injector
255 Fuel pump
Kit Components
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
https://www.clublexus.com/forums/is3...-for-sale.html
3. No spamming multiple classifieds forums with your for sale items. This means pick one and only one classified forum to post your for sale item in, even if it possibly pertains to several Lexus models. Please do not place URL links to posted classified sales in your profile or signature, that is not allowed on our forum.
soo chrisp
06-23-10 06:18 AM
Lexus_IS300
IS - 1st Gen (2001-2005)
12-18-01 10:50 AM
