CA FS (Socal): Endless 6-Pot Compact Mini Brake Kit
Endless 6-Pot Compact Mini Brake Kit for SXE10 (IS300 2001-2005)
Originally bought as the System Kit that included the one piece rotors 296x32.
Two years later I decided to upgrade the rotors to the two disck larger rotors 324x30. This required the larger two piece disc as well as different mounting brackets. I've since gone back to the OEM brakes and putting these up for sale.
Everything for sale is below:
- x2 6Pot Compact Mini Blue Endless Calipers
- x2 Endless Swivel Teflon Coated Stainless steel brake lines
- x2 One Piece Zeal Straight-6 Slotted Rotors 296x32
- x2 Endless brake caliper brackets for the 296x32 Rotors
- x2 Two Piece Zeal Straight-6 slotted rotors 324x30
- x2 Endless bracke caliper mounting brackets for the 324x30 rotors
- All the necessary bolts/washers needed to bolt the kit in.
- x2 Zeal Straight-6 Rear slotted rotors
- Also included are fairly new Endless SS-M brake pad in the calipers
With all the parts above, it gives you the option to either mount the OEM Size discs, or
go to the larger two piece disks if you wish. The two piece disc are lighter of course than the
OEM. Also have all the manuals and installation instructions for the brakes.
Brake Kit Sold 6/22/2010. Mods please remove.
New CL Vendor Futura Design Big Brake Kits for 2IS
Futura Design Brakes
CL Vendor Products for 2IS
08-19-15 07:47 PM
