FL ***700hp IS300 partout*** Turbo kit, engine, Fuel, GTE Style mani, trans etc...
Every part listed has less than 4000 miles the clutch has 1500 miles. If you want to buy more than 1 thing as a sort of package i can work on a deal for you. ALL PRICES ARE + SHIPPING
Here a vid of the car on low boost...
http://www.youtube.com/watch?v=DwF3qtz2MmA
2JZ-GE Engine *Blue Printed* $4000 OBO
![](http://i24.photobucket.com/albums/c18/xboostx_/TheIS3almostdone008.jpg)
The engine will come with an ATI Damper, water pump, tensioner, and power steering pump.
Ported IS300 Head
Brian Crower Springs
Brian Crower Retainers
Ferrea Locks and Valve Seals
Valve job
Decked and Cleaned
ARP studs
TT Head Gasket
JDM TT Valve covers
Block:
The block was blue printed with the ARP hardware. It was line honed, had all the clearances check etc. and was cleaned.
GTE Pistion and Rings
GTE Rods
Clevite bearings
ARP Main Studs
ARP Rod bolts
TT Supra oil pump
Transmission $1100 OBO
Soarer R154 with modified Shifter fits the IS perfect and electronic speed sensor (rare). Shifts perfectly no grinds. Shifter feels tight, no slopiness to it.
Clutch & Flywheel $1400
The kit is the lastest version from spec and they sent me the new hydrualic slave which is included BRAND NEW
Spec Twin disc
Spec Billet Flywheel
Spec Hydrualic slave & SS braided lines
Wilwood Cluth Master
Turbo Kit Custom$2500 OBO
I made 600whp with this setup at only 22psi on E85, and at 7000rpm the power never dropped off.
Master Power T70 with 71mm front wheel .70 front housing .68 rear housing. Started to spool around 3800 rpm. (has one or 2 threads on the front housing that need to be retapped)
Drewgo Turbo Manifold
All 3 inch piping and Tbolt clamps
Huge intercooler
Tial 44mm Wastegate
Turbonetics Godzilla Blowoff valve (Sounds amazing!)
-10 return line
Turbo feedline
Black couplings
![](http://i24.photobucket.com/albums/c18/xboostx_/IS2.jpg)
![](http://i24.photobucket.com/albums/c18/xboostx_/IS.jpg)
Fuel system Custom $900 OBO
I will also include a hob switch, wires and relay which i used to trigger the second pump (boost reference)
Power House racing Fuel hanger (modified)
-8 Fuel Rail
Acceleronics 83lb injectors
Denso Pump 1
Walbro Pump 2
Twin -6 lines into 1 -8 line
Jegs SS Fuel filter
Aeromotive FPR
-6 return
GTE style Intake Manifold with billet T/B & TPS sensor SOLD
more parts to come...
triple gauge pod
haltech
driveshaft
etc...
Ported IS300 Head
Valve job
Decked and Cleaned
ARP studs
TT Head Gasket
JDM TT Valve covers
Block:
GTE Rods
Clevite bearings
ARP Main Studs
ARP Rod bolts
TT Supra oil pump
Spec Twin disc
Huge intercooler
Tial 44mm Wastegate
-10 return line
Turbo feedline
Black couplings
-8 Fuel Rail
Denso Pump 1
Walbro Pump 2
Jegs SS Fuel filter
Aeromotive FPR
-6 return
triple gauge pod
haltech
driveshaft
etc...
Oh darn i forgot about the vouch thing. I will get one. You can also check my trader rating on my.is and supraforums.
03SPDesign and Anthony, a bunch of SoFL guys know me aswell, LMK if you guys have any questions. And this engine will bolt right up to a GS
2JZ-GE Engine *Blue Printed* $4000 now $3500 OBO
Ported IS300 Head
Valve job
Decked and Cleaned
ARP studs
TT Head Gasket
JDM TT Valve covers
Block:
GTE Rods
Clevite bearings
ARP Main Studs
ARP Rod bolts
TT Supra oil pump
Turbo Kit Custom$2500 now $2000
Huge intercooler
Tial 44mm Wastegate
-10 return line
Turbo feedline
Black couplings
![](http://i24.photobucket.com/albums/c18/xboostx_/turbokit.jpg)
Fuel system Custom SOLD
GTE style Intake Manifold with billet T/B & TPS sensor Sold
Haltech E6X SOLD
Triple Gauge pod with Boost, Oil Pressure and EGT gauge SOLD
Driveshaft for the R154 on an IS300 Pending
Altezza OEM Start Button SOLD
Haltech E6X SOLD
R154 Transmission SOLD
Clutch & Flywheel SOLD
Ported IS300 Head
Valve job
Decked and Cleaned
ARP studs
TT Head Gasket
JDM TT Valve covers
Block:
GTE Rods
Clevite bearings
ARP Main Studs
ARP Rod bolts
TT Supra oil pump
Huge intercooler
Tial 44mm Wastegate
-10 return line
Turbo feedline
Black couplings
Haltech E6X SOLD
Haltech E6X SOLD
Ported IS300 Head
Valve job
Decked and Cleaned
ARP studs
TT Head Gasket
JDM TT Valve covers
Block:
GTE Rods
Clevite bearings
ARP Main Studs
ARP Rod bolts
TT Supra oil pump
Huge intercooler
Tial 44mm Wastegate
-10 return line
Turbo feedline
Black couplings
Haltech E6X SOLD
Haltech E6X SOLD
Ported IS300 Head
Valve job
Decked and Cleaned
ARP studs
TT Head Gasket
JDM TT Valve covers
Block:
GTE Rods
Clevite bearings
ARP Main Studs
ARP Rod bolts
TT Supra oil pump
Huge intercooler
Tial 44mm Wastegate
-10 return line
Turbo feedline
Black couplings
Haltech E6X SOLD
Haltech E6X SOLD
