CAN-Vancouver FS: K-sport air ride kit
K Sport air ride suspension(basic kit, but i upgraded to WAY better valves and 3/8 line)
comes with
-all DOT approved airbrake fittings(good dfor 200psi +) there compression fittings in the trunk and on each corner i have ALKON PTC fittings(i had zero leaks with this set up)
- all DOT approved 3/8's nylon air brake line
- 1 Viair 380c compressor
- 1 5 gallon tank
- 4 corner 36 way dampening coilovers(but isntead of spring its a bag)
you have 5" of lift or drop with the air ride and it rides like stock and bolts up with no problems, only mods you have to do to your car is drill 4 holes for the air lines and then rig up switches and gauges..
I bought an ASCO valve manifold with 8 valves(4 corner control) i paid 450$ in august
the entire kit was only used from the 2nd week of august till october 30th
i have NEVER had a problem with any components in this kit.
i will also throw in an airlift autopilot brain + controller but dont have pressure sensors i took it out because it was extremely unreliable, but its a freebie (800$ kit w/ pressure sensors)
I would like to get $3000 OBO for the entire kit
TH motorsports is selling same kit for about 2800 i think, but thats without the water trap(70$), 3/8 DOT approved lines and fittings(another 100$) and the valve manifold(450$ prior to shipping)
if your localish i can help you install in a day...
![](http://img.photobucket.com/albums/v481/sandhu/th_rearairstruts.jpg)
![](http://img.photobucket.com/albums/v481/sandhu/th_frontairstrut.jpg)
![](http://img.photobucket.com/albums/v481/sandhu/th_photo6.jpg)
![](http://img.photobucket.com/albums/v481/sandhu/th_photo3.jpg)
heres a pic of it totally laid out on 19" rims w/ 235/35's.
if you have any questions please pm or call me
778 808 3680
comes with
- 1 5 gallon tank
778 808 3680
comes with
- 1 5 gallon tank
778 808 3680
comes with
- 1 5 gallon tank
778 808 3680
ac921ol
04-14-10 12:43 AM
