CA ENDLESS 6piston BBK, JIC front strut bar
SOCAL has priority, none of these prices include shipping, and if you want them shipped you will pay for shipping, shipping materials and insurance(if wanted)+3% paypal charges
this is not a complete list yet. i will post more as i pull things off or find them in boxes.
Endless 6-Pot Compact Mini Brake Kit for SXE10 (IS300 2001-2005)
Originally bought as the System Kit that included the one piece rotors 296x32.
Two years later I decided to upgrade the rotors to the two disck larger rotors 324x30. This required the larger two piece disc as well as different mounting brackets. (i am now the new owner, and i have not even mounted this kit due to certain issues with my car so everything is as the same as when i bought i)
Everything for sale is below:
- x2 6Pot Compact Mini Blue Endless Calipers
- x2 Endless Swivel Teflon Coated Stainless steel brake lines
- x2 One Piece Zeal Straight-6 Slotted Rotors 296x32
- x2 Endless brake caliper brackets for the 296x32 Rotors
- x2 Two Piece Zeal Straight-6 slotted rotors 324x30
- x2 Endless bracke caliper mounting brackets for the 324x30 rotors
- All the necessary bolts/washers needed to bolt the kit in.
- x2 Zeal Straight-6 Rear slotted rotors
- Also included are fairly new Endless SS-M brake pad in the calipers
$1800
With all the parts above, it gives you the option to either mount the OEM Size discs, or
go to the larger two piece disks if you wish. The two piece disc are lighter of course than the
OEM. Also have all the manuals and installation instructions for the brakes.
JIC Front strut bar (aluminum)
$120
the bar is a bit dirty from sitting in the shop and the last photo is a picture of where the bar rubs against the hood insulation, just wanted to be honest with you that its not all sparkly and filled with rainbows and happiness.. my car has run BW more than a couple times.
$1800
$120
hey sorry about the late response, ive been in and out of the hospital for a few days ill try to get the photos up asap.
on a side note: trolls can gtfo my internetz.
yes this is the full kit comes with 2 brackets also (two different sized brackets for the oem size rotor and the upgraded 324 rotor, this also means that you can run your OEM rotors if you would like.)
and i dont believe endless makes a rear kit, and YES! this will fit the sportcross <3
