MD SRT intake and Intake manifold with TB [24hr]
Marshall B
Jessup MD
racedesignz@aol.com
$300 SHIPPED , need new filter
![](http://i77.photobucket.com/albums/j41/supra7tt/ISINTAKE1_zps195c9043.png)
Picture and info from website ,Intake BRAND NEW NEVER INSTALLED , EVERYTHING NEEDED TO INSTALL ON YOUR CAR @$1500 OBO SHIPPED
SRT 2JZ-GE CNC Racing Intake Manifold Lexus IS300 (2001 - 2005) Lexus GS300 (1998 - 2000) Price: $1,995.00
1.CNC machined flange; was designed using CAD and port matched to factory head. (The ports can be opened up for ported and polished heads).
2.Oval "Shorty" intake runners for maximum mid/high RPM power. (Yes this is not for the faint of heart and definitely not entry level).
3.Oversized Intake plenum.
4.Plenum flange CNC machined and CAD designed which also incorporates CNC machined built-in venturi's.
5.75mm TB (optional 80mm, 85mm or 90mm available).
6.New throttle cable for plug 'n' play setup.
7.New Fuel Rail (Fuel lines, fittings and regulator are optional.)
8.Power Steering reservior requires modification (for clearance).
9.Will fit with the Factory ECU box same location (it will need to be moved over about an inch toward the driver fender, takes 5 minutes
Jessup MD
racedesignz@aol.com
![](http://i77.photobucket.com/albums/j41/supra7tt/pic1_zpsafd402cc.jpg)
you have 24 hours to have a qualified (500+ posts and 1+ years) member post up a vouch for you to be able to sell the intake manifold.
https://www.clublexus.com/forums/whe...d-read-me.html
