CA FS: JDM power folding mirrors
I have up for sale a pair of JDM power folding mirrors
10/10 condition, clean pair in pearl white
Also I have the connection with wires attatched to the door controls so all you have to do is match the wires and solder/splice them in which makes the install so much easier!
$250
$250
no sorry the skins do not transfer since the jdm housing is smaller than the usdm. if you read in the DIY it says in the paragraphs below the harness pictures:
"Another approach is to fabricate mounting points for the JDM motor inside the USDM housing which will of course allow for the use of the USDM mirror and mount. This is the preferred yet most time-consuming solution. One such method in which to attach the JDM motor to the USDM housing is illustrated below:"
So if you want, you can swap the jdm motor into your usdm housing which will let you keep the heating function of the mirrors and let you keep your skin and will not require painting and have the mirrors adjusted for LHD use
the DIY shows how to swap in the motor into the usdm housing or vise-versa
Tuanville
03-13-18 11:33 AM
howiedoit
SC400 / 300 Classifieds
03-08-06 08:07 AM
