GA NA-T Partout
NA-T Partout
Hey All. I built a 2jzge (non-vvti) NA-T (240sx chassis) and lost compression on cylinder 6 after the build. I've decided to part it out and try again at a later time when i'm finished with school. I made a spreadsheet of the parts I have available for sale in the picture below. All parts have less than 30 miles on them. Most parts are just about brand new and are marked slightly under retail price. Prices negotiable, but to an extent. I am located in Atlanta, Ga. Shipping is not an issue. Please feel free to PM me or text me (678-327-8571) for any details about anything that is unclear. If there is something you need but don't see listed feel free to ask. Everything is still on the car at this point so please bare with me. I will begin total disassembly during the next several days. I am mostly trying to gauge interest as I begin to take things off here over the next few days/weeks. I will add things to the list as I pull them off. Thanks for looking!
Front sump oil pan (upper and lower) $250
240sx Driver side conversion JZ AN Fuel lines (Russel Fittings/lines, 6AN Feed/return) $300
Precision 6266 (.81 A/R, Jet coated exhaust side, Journal Bearing) $1,000
2jzgte valve covers (-10AN bungs welded, wrinkle black coating) $400
Oil Feed/Drain (-4an/-10an Russel fittings and lines) $120
2jzgte Spark plug cover (OEM Color. Purchased new through Curt Aigner) $100
Competition Clutch Lightweight flywheel $225
FAL 420 S-blade slim fans $300
Doc race turbo manifold (Dual Wastegate 2jzge, Open T4) $1,400
Mishimoto Black S-Line Intercooler $200
SRT Intake manifold with fuel rail mirror polished (2jzge) $1,700
OEM Rebuilt MKIII R154 (shifter extension) with Southbend Clutch (Stg 4 (600wtq capacity))
$2,000
Freed engineering 2jz/r154 240sx swap mounts $275
44mm EWG Dump tube $80
MKIII R154 OEM trans mount $50
Cusco 240sx Engine mounts $220
Oil Cooler (MRP thermostatic sandwhich plate, Russel AN lines/fittings, Mishimoto cooler) $250
Tial Q BOV $180
240sx Fortune Auto 500 Coilovers $850
ProEFI 128 (Color CAN, Flex fuel, Comm Cable, Extra pressure sensor) $4,500
SPL Camber arms $250
ProEFI CAN Display suction cup windshield mount $75
SPL Toe arms $250
Mishimoto Thermostat $45
SPL Eccentric Lockout kit $50
Billet Distrubutor cap (Driftmotion) $60
JDM Kouki Wing/Trunk (freshly paint matched OEM Super Black) $450
7mgte fan shroud (OEM Never used) $65
JZ S14 3.5" Straight pipe with 18" Vibrant resonator (V-band dowpipe connection) $225
Tial 44mm Wastegate $320
S14 ABS VLSD w/axles $300
Fuellab 51502 FPR with Radium Engineering gauge $140
SR20 240sx Mishimoto Radiator $225
Shaftmasters 2jz S14 R154 driveshaft $300
DAFT Sway bar spacers $50
Enkei RPF1 (5x114.3, 17x9 +22, 17x10 +38, NT555 255/40, NT555R 275/40) $1,350
ID1000 $700
LQ9 coilpacks (with boots/springs) $155
Walbro E85 400lph fuel pump $135
2jzge head (Decked, vacuum checked, cleaned prior to assmebly) $200
2jzge block (Clevite internals, TT MHG, ARP Headstuds, Cyl 6 60psi) $200
$2,000
Tial Q BOV $180
SPL Toe arms $250
ID1000 $700
CHINCHIN
12
07-05-18 06:02 PM
Icy350
19
05-05-14 07:42 AM
