CA FS: Gauge Cluster Speedometer
Old 07-25-16, 11:17 AM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
Default FS: Gauge Cluster Speedometer
This is a Working Gauge cluster. I bought this because I ONLY needed the gauge needles. You can easily pop off the needles from your existing gauge cluster and install them on this one.
There is a small crack in the lower right corner (see pic). You can exchange it with the clear cover from your existing cluster if you have it. Otherwise The crack will be mostly covered up when installed behind the dash.
I believe the cluster has very low odometer milage on it, but I would need to take apart my car to plug it in and find out. Just message me if that is important to you and I will find the time to plug it in and take a picture.
$100
Attached Thumbnails FS: Gauge Cluster Speedometer-image.jpeg
RMMGS4 is offline
Old 07-25-16, 11:19 AM
RMMGS4
RMMGS4's Avatar
Crack on lower right lens. If you have the original cluster, you can replace the cracked lens with your original
RMMGS4 is offline
Old 08-13-16, 11:38 AM
Jamesap79
Jamesap79's Avatar
I have a mint JDM 6 speed cluster
Jamesap79 is offline
SC_Edgar
SC- 1st Gen (1992-2000)
06-28-18 11:40 AM
TRDmike
SC400 / 300 Classifieds
06-30-12 09:36 AM
md531e
12-12-10 01:42 PM
Quick Reply: CA FS: Gauge Cluster Speedometer
