For Sell: Turbocharged 2002 IS 300
For Sale:
2002 Turbocharged Navy Blue IS 300
Why am I selling the car?
I do not have as much time as I would like to play around with the car.
Engine Modifications
1. Carillo Rods
2. Supra TT Pistons
3. SPS Carr Rod Bolts
4. PHR SS Piston Ring Set
5. ARP Head Stud Kit
6. HKS 1.2mm Metal Head Gasket
7. Blueprinted and Balanced Short block
Cylinder Head Modifications
1. PHR 246 degree exhaust camshaft
2. Adjustable Cam Timing Gear, exhaust
3. PHR Dual Valve Springs
4. PHR Ti Valves
5. PHR Ti Lightweight Retainers
6. Heat coated exhaust ports
7. Camshafts degreed and shimmed to spec.
Fuel System Modifications
1. PHR 17.5mm ID Fuel Rail
2. HKS 1000cc Injectors
3. 6AN Fuel Feed and Return lines
4. PHR In-tank Fuel Pump Bracket Kit
5. PHR High Flow Fuel Pump 300lph
6. 6AN SS 40 micron fuel filter
7. Aeromotive Fuel Pressure Regulator
8. 100 psi liquid filled FP gauge
Turbocharger System
1. ITS GT 62 Turbocharger
2. Mandrel Bent 3" Downpipe and Midpipe
3. Tanabe Super Medallion Catback
4. HKS 200mm Air Filter
5. Aluminum 2.5" IC piping
6. Blitz Blow Off Valve
7. Spearco 24" Intercooler Core
Electronics
1. Motec M4 PRO ECU
2. Motec Wide Band Lambda Option, Sensor
3. Raychem Custom Wiring Harness
4. 3 BAR MAP Sensor
5. NTC Air Temp Sensor
6. TRD Triple 60mm Gauge Pod
7. Apexi Boost, Oil Press, Fuel Press 60mm
8. HKS EVC 4 Boost Controller
Driveline
1. Getrag Supra Six Speed Transmission
2. RPS Stage 3 Clutch
3. PHR 3" Steel Driveshaft
4. TRD Limited Slip Differential
5. Syncromax Synthetic Gear Oils
Body
1. HKS Hypermax Damper II Coilovers
2. Daizen Sport Tuning Sway Bars
3. Brembo Front Brake Upgrade
4. RMM Carbon Fiber Lip Spoiler
5. Forgeline 17x8 Wheels
6. Yoko AVS 215/45F and 245/40R Tires
Stock Parts:
1. Strut and springs
2. Catalytic converter
3. Exhaust
4. Owner’s manual
5. One master key, one valet key and one wallet key
Aftermarket Spare Parts:
1. HKS springs
2. 6 NGK 3330 Sparkplugs
3. 8 quarts of Castrol 10w30 Non-synthetic
Miscellaneous Parts:
1. Ultraguard custom car cover
2. Stormshield cover bag
3. Coverking lock and cable kit
4. Covercraft custom fitted sunshade
5. McGard wheel locks with extra key
6. 2002 Lexus IS 300 factory repair manuals (both editions)
7. One extra master key
Services Performed:
1. Oil change at 997 miles using Castrol 10w-30 Non-synthetic
2. Alignment at 7,530 miles
Known Problems:
1. The carbon fiber center for the RMM lip has been chipped
2. Slight 3” dent on top of the windshield
3. Vibration when braking from 55-60mph
I have all the receipts.
History Notes:
Less than two miles of ownership, I over boosted it by accident and blew the short block. I immediately shipped the car back to Powerhouse Racing for repairs. Jarrett installed a new 2JZ-GE short block, rods, pistons and other miscellaneous things to get the car back to its prime condition when I first recieved it. I only used a private enclosed car carrier service to transport the IS 300 to and from Powerhouse Racing’s facility in Texas, and also for the initial time I shipped the car from Powerhouse Racing to California. I spent approximately $5,200 in shipping alone…
Before the IS 300 was shipped back to Powerhouse Racing for repairs, Daizen sway bars and HKS Hypermax Damper II coilovers were installed.
Background:
The odometer now has 7,761 miles. I put approximately 1,200 miles on the car since I took ownership after the repairs done by Powerhouse Racing. 99% of the miles were on a highway driving between 60-65 MPH and under 3,500 RPM.
Price: $45,000
If you have any questions or will like to see pictures, please feel free to call me at (949) 235-1433 or email at ekay@clublexus.com. I can be reached occasionally on AIM at ClubLexus02.
Thank you for looking.
I made some edits. Jarret did not install a GTE block; it just says GTE on the receipt.
1. Carillo Rods
2. Supra TT Pistons
4. PHR Ti Valves
Turbocharger System
Electronics
1. Motec M4 PRO ECU
4. 3 BAR MAP Sensor
Driveline
Body
Stock Parts:
3. Exhaust
4. Owner’s manual
1. HKS springs
Services Performed:
Known Problems:
History Notes:
Background:
Price: $45,000
Lexus Connoisseur
Ethan, you need to take me for a ride before you sell it!
I am pretty much done with cars, in general. I like my 1993 LS 400. You put the badboy in "D", hit the gas pedal and move!
I put a lot into this IS 300, and I never held back; hence, I bought almost everything out there, including custom car covers, locks, wheels locks, extra key and etc. I am still awaiting the Toms braces from Steve; I am not sure what the status of the order is. I was about to buy a trailer (...LX 470/Tundra/Tacoma to TOW the trailer), Motec Lambda meter and upgrade the M4 to M48 ECU complete with new wiring and harness. A 12 point rollcage did come to my mind at some point...but I was like, it MAY be a 10-11 second IS 300, however, I am definately incapable of driving it to the car's full potential. Basically, I was going to go full 10 yards. However, my time is now very limited, including on weekends. So, something had to go, and I decided to let go of the car instead of the other options availabe to me.
One more note, people called me crazy when I spent $3,000 in shipping the car to and from Texas after 2 miles/10 minutes of ownership. lol!
Richie and Ryan, well, if the car is still here, then yeah, I will give you a ride for what it is worth. I never could seem to bring out the potential in the car unlike other drivers who have taken the car for a spin.
Keeper of the light
Ladies and Gentleman, this is also the featured car of the month!
https://www.clublexus.com/index.php/...iew/2258/1/10/
It's practically famous. dig deep.
Originally posted by Static911
TurboB6,
Sorry, I'm not looking for any trades, especially modified cars, at this time.
TurboB6,
...you'll be lucky if someone pays you thirty grand for it...........highly unlikely you'll find an extremely unique buyer for a car that has been 'raced' numerous times.....
...let this be a lesson to the people that pour money into...'mods' as the actual value of the car slides ever downward...
