Does anyone know if a IS250 manual will fit on a 350?
#49
Tech Info Resource
No Supra engine/ECM supports CAN (or BEAN), so your gauges won't work along with just about everything else using CAN & BEAN that depends on an ECM input. I have a friend with an MR-S who wants to put in a 2ZZ and keep his SMT, but the SMT uses CAN between the ECM and the transmission ECU, so you can't separate them and have a working transmission. Similar problem.
The gearbox is the RA-62. It's a variant of the RA-60 in the Tacoma.
#51
Tech Info Resource
I don't know which would be the kiss of death first - height or length, but one of them is going to make it impossible.
#52
Tech Info Resource
