Amp wiring diagrams?
Old 02-13-07 | 10:52 PM
1022it's Avatar
1022it
Post Amp wiring diagrams?
Can anyone get their hands on a wiring diagram for the factory (non ML) amp? or at least some info on how we can integrate the factory radio with aftermarket amps. I have plenty of car audio knowledge, but nothing on this new stuff. I want to bypass the amp so i can put a little more power to the highs and run a sub.
Old 02-14-07 | 01:28 AM
lexusaudio's Avatar
lexusaudio
heres the 2006 is250 av terminals.pdf. i am an oem audio expert so bypassing the amp is your expertise. the speaker outputs are back to the 6 pin 10 pin so you can use the cheap 1988 up toyota speaker adapters but changing some of the wires to the new pinouts.
File Type: pdf
Old 02-14-07 | 09:15 AM
1022it's Avatar
1022it
THANKS! This should be sufficient!
Old 02-14-07 | 11:08 AM
isforme's Avatar
isforme
A little more help. Luck!
File Type: pdf
Nick217
07-29-21 05:19 PM
joeker
06-02-19 09:11 PM
Deception
09-06-14 08:42 PM
boogy886
07-28-10 06:44 AM
hazed06
09-21-09 08:22 PM
Quick Reply: Amp wiring diagrams?
