Uh-Oh.......Exhaust leak in header area
Old 03-22-07, 08:13 AM
  #61
JBrady
JBrady's Avatar
Originally Posted by Hameed
This is not good news..........
I placed my order for the "new and improved" version on Thursday last week and I am concerned that it may not be "improved" enough after seeing yours.
Loren did say that the down pipe is a thicker gauge of steel now, so hopefully this problem will not happen again on the new headers.
Hameed, I understand your concern.
I am encouraged by the use of a heavier gauge of pipe being used in the problem area. That should fix cracking at this location.
Old 03-22-07, 08:17 AM
  #62
JBrady
JBrady's Avatar
Originally Posted by slowdiver
sorry to here the bad news bro...
looks like I'll be in the same boat at some point in the future as my new weld stops at the exact same spot your new crack is.
It is definitely time for S&S to publicly address this issue and in the meantime stop selling headers for our cars.
Slow, what do you recommend? They have so far handled all warranty issues admirably. The change to thicker gauge pipe at the effected joint makes sense to me. Coupled with the modified welding this would seem to be the ticket. What are you hoping for?
Old 03-22-07, 10:06 AM
  #63
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
Originally Posted by angus
i'm wondering if anyone has considered adding flex joints to thier exhaust,and possibly more brackets/bracing,i have these headers and i honestly beleive this will eliminate the problem
I am contemplating to run flex pipe after the cats.
I'll look into this when I have my x-pipe install / resonator removal done in a few weeks. They will be replacing the whole piping from cat to muffler, so this would be the right time to do it.
I have the original headers, so I don't have any reinforced welds at this point, so this would be a true test to see if I get any cracking down the road.
Old 03-22-07, 10:20 AM
  #64
Hameed
EV ftw!!!
Hameed's Avatar
Glen, are you referring to this section (see piping on the left hand side - the Y-section.
You are getting braver and braver . I remember when you talked about this last year you were not planning to remove the resonators so that you could maintain some "stealth" to your ride.
Old 03-22-07, 10:40 AM
  #65
trbopooh
trbopooh's Avatar
i recently did the x pipe w/ 2in. piping without resonators running to the blitz nur spec exhausts. HOLY $H1T!!! it was freaking loud and raspy. my sis said my car sounded like a rocket. i immediately went back and added two resonators.
Old 03-22-07, 10:44 AM
  #66
trbopooh
trbopooh's Avatar
that's a good idea. with the headers it's hard to tell if you have a crack in them unless the crack gets real bad or you do a visual inspection with a mirror. i will say that loren is a consummate professional.
Old 03-22-07, 10:55 AM
  #67
RMMGS4
RMMGS4's Avatar
Yup that's a good shot, but now that I see the brace on the tranny, I'm not sure if it makes sense or if there is enough room to add a flex pipe between the brace and the cat. I'm just thinking out loud here. I could move the brace point a few inches towards the rear to make more room for the flex pipe. Until I spend some time under the car, I won't know what's feasible.
Well I have been going back and forth on the resonator part, but with the RMM mufflers being very conservative I am hoping it will stay mellow and only open up at WOT, which would be acceptable to me. Then there's always the option to install hi performance resonators, if there is such a thing.
Old 03-23-07, 05:39 AM
  #68
kevbleek
kevbleek's Avatar
Sup fellas. Just browsing through the posts and saw this. I got my headers a while ago from s&s, just waiting on a break from work to throw them in. I know that s&s has had this on going problem with the cracked headers. i got mine about 2 months ago so, im not sure if i even got the thicker gauge piping. Either way i think im going to go ahead and weld them to reinforce them. My question is, what type of "beading", if thats what its even called. The wire you use to actually weld the "bead", does it have to be high temp or anything out of the ordinary or would i be able to use the same wire i used to solder wires? Thanx in advance and i defitnitely need to stop lurking and post up some pics of the recent work ive had done, thanx to all the knowledgable members of clublexus!
Old 03-23-07, 06:35 AM
  #69
Hameed
EV ftw!!!
Hameed's Avatar
I doubt very much you got the thicker gauge piping as that particular run is not even finished yet. It will be finished by next week.
Old 03-23-07, 08:45 AM
  #70
BA_GS400
BA_GS400's Avatar
Hey KevBleek, as I remember from my welder, he did have a choice of two different kinds of "rod".
When he realized it was a stainless steel header, I *think* he said he went ahead and used a stainless welding rod.
I was thinking about welding a short metal plate from one pipe to the other. (where the crack is at to an adjacent pipe)
Old 03-23-07, 09:57 AM
  #71
JBrady
JBrady's Avatar
Just to clarify. These are mild steel with ceramic coating. They are not stainless. I am not a welding expert but know that you can use stainless rod on mild but I do not know the strength of the final weld when doing so.
KevBleek, you should contact S&S and asked what version you have and any welding recommendations. Also consider if you modify the headers before you run them you risk voiding your warranty.
BA, you have been VERY helpful on this issue and I suggest a call to Loren as he may just send you an updated passenger side.
Michel1
IS F (2008-2014)
17
01-11-19 02:29 PM
ROSCOGX470
GX - 1st Gen (2003-2009)
19
01-01-17 10:54 AM
hihopes
Performance & Maintenance
02-22-13 09:19 PM
altezzaguy
IS - 1st Gen (2001-2005)
02-18-12 05:20 PM
SLVRGS
GS - 1st Gen (1993-1997)
09-18-02 07:40 PM
Quick Reply: Uh-Oh.......Exhaust leak in header area
