AC/FILTER- Warning Light?
Old 05-11-07, 06:18 AM
LSMAN
LSMAN's Avatar
Default AC/FILTER- Warning Light?
Start up the 2003 LS430 today. Red flashing triangle light and message says:
AC/Filter ... needs to be changed?
Any idea on what - when and where?
Thanks,
LSMAN
* The warning light goes off after a few seconds.
Old 05-11-07, 11:54 AM
CG lover
CG lover's Avatar
filter is in the back of the glove box and accessed through the same area,, really easy to change,, can buy them from various on-line Lexus dealers or aftermarket suppliers,, check in your manual on how to reset the control as it should be calling for a new one every 15k miles,,
Old 05-11-07, 12:00 PM
racinstyle
racinstyle's Avatar
I dont have my manual, how do you reset this change a/c filter switch?
Old 05-12-07, 11:36 AM
Topshottaz
Topshottaz's Avatar
i get the same warning everytime i start my car and even after i changed the filter, it still did the same thing
Old 05-12-07, 02:59 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
to reset, hold the OFF button while the ignition is in the ON position.
Old 05-12-07, 06:03 PM
rduncan265
rduncan265's Avatar
Where is the OFF button?
Old 05-12-07, 06:15 PM
racinstyle
racinstyle's Avatar
Sweeeet, you da man!
Old 05-14-07, 07:31 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
The one located on your climate control. Make sure the car is off and the key is in the ON position. (if it doesnt work, try it in the ACC position).
I think you have to hold it for 3-4 seconds. As much as I knew my car, reading my manual, i learned so much interesting information.
For example, I didnt know you could lock up the rear control panel on the ultra's by holding the button labeled with the key. I will post a thread with pics soon.
Old 05-15-07, 07:00 PM
sirdoc99
sirdoc99's Avatar
Is it in the top or bottom glove box? Anyone have a quick write-up on how to change this out? I'm sick of my car smelling like feets
Old 02-07-08, 08:22 AM
ttran1999
ttran1999's Avatar
Default A/C Filter message on 04 LS430
Hi all,
I just replaced the A/C filter on my LS430 but don't know how to reset the A/C Filter message. I know that you can reset the message by holding down the AC OFF button for a couple of seconds while the engine is off, but the problem is that my car is equiped with Navigation therefore there is no AC off button for me to push. Thanks in advance.
ttran1999
Old 02-07-08, 08:37 AM
ttran1999
ttran1999's Avatar
How do I reset the AC Filter message since I have a Navigation system?
Old 02-07-08, 09:19 AM
ludes98
ludes98's Avatar
If it is the one in your navagation screen you can reset that one in the maintenance screen once you browse to it. If it is the one in your instrument cluster, then you have to have the ignition on with the engine off and hold "OFF" for the AC until reset is displayed.
Old 02-07-08, 09:54 AM
ttran1999
ttran1999's Avatar
Thanks ludes96. I looked in the Maintenance screen and the only thing I see is the Air Filter reset. I will play around with the screen again. Thanks.
Old 02-07-08, 11:10 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Old 02-07-08, 10:12 PM
steveaus
steveaus's Avatar
Can anyone provide a link to buy one of these filters online? I'm having trouble finding one -- lots of oil and air filters, but A/C not showing me the love.... Dealer wanted $95 to replace mine.
Quick Reply: AC/FILTER- Warning Light?
