help please read!! 1jz swap!!
Old 06-18-07, 10:05 PM
nismo2trd
nismo2trd's Avatar
Default help please read!! 1jz swap!!
well i just bought a 1jz from suns auto here in houston. this engine looks fine and all, but heres a problem im dealing with. the guy that runs the shop doesnt know if the engine is from a supra or a soarer and the motor was dirt cheap, good compression and no plays with the turbos, so i coudlnt miss this deal. the clips to the ECU on the 1jz is gray, and the plugs looks like a triangles. it looks nothing like the one i have on my sc300, could it be a soarer harness or a supra harness? my other question is the motor came with the auto tranny. the ecu is A/T would that cause a problem? i have a W58. would the w58 bolt up to the 1jz? and about the flywheel and the clutch can i use the 2jz flywheel and clutch for the 1jz?
thanks for the help
-stan
Old 06-19-07, 05:29 PM
nismo2trd
nismo2trd's Avatar
can someone please help me?
Old 06-19-07, 05:32 PM
Rising_Sun
Rising_Sun's Avatar
Please post pics of the ECU and harness. Does it have a Hydropump fan assy?
Old 06-19-07, 05:33 PM
plex
1UZFE/2JZGTE
plex's Avatar
Do you have any pics of the harness and ecu? Yes the W58 will bolt up do a search.
Old 06-20-07, 06:13 AM
gario
gario's Avatar
those questions have been answered before.
use the 2j flywheel and buy an sc300 clutch kit and the w58 bolts on. the a/t ecu works as well. so are you saying you might have a soarer harness and a supra ecu? or do the plugs don't fit into the ecu? everything should plug in.
Old 06-20-07, 11:26 AM
nismo2trd
nismo2trd's Avatar
i love you man. hahah jk
Old 06-20-07, 11:27 AM
nismo2trd
nismo2trd's Avatar
ill have pictures within few hours
Old 06-20-07, 05:17 PM
got_trd
got_trd's Avatar
If the ecu plugs on the harness have 2 rows of pins going across its not a soarer harness and likely a supra harness...
example of one connector
If the ecu plugs on the harness have 4 rows of pins going across its a soarer harness
example:
i tried... hope you get what i meant by that...
also-
supra= front sump oil pan, hydrofan set-up
soarer= rear sump oil pan, regular clutch type fan
Old 06-20-07, 07:33 PM
nismo2trd
nismo2trd's Avatar
example:
also-
oh man no good, i need a rear oil sump. anyone have one?
Old 06-20-07, 07:57 PM
nismo2trd
nismo2trd's Avatar
yay or nay
Old 06-21-07, 08:10 PM
nismo2trd
nismo2trd's Avatar
helppppppp
Old 06-21-07, 09:50 PM
audi2nr
audi2nr's Avatar
double post
Old 06-21-07, 09:51 PM
audi2nr
audi2nr's Avatar
heres my 1jz ecm from a chaser, should be the same as a soarer 1jz ecm your 1jz is missing some parts, ie stock bov some turbo coolant hoses ect...
Old 06-22-07, 12:34 AM
nismo2trd
nismo2trd's Avatar
how did u get it to work?
the body plugs are not the same.
Old 06-22-07, 07:35 AM
Bean
Bean's Avatar
The Supra is a midsump just like the Soarer. The Chaser is a frontsump IIRC. I'm def sure on the Supra though.
Quick Reply: help please read!! 1jz swap!!
