How to change nav DVD without breaking everything?
(I'd like changing from 2005-06 v1 to 2006-07 v2 nav data disk)
Sorry this seems a simple question, but I didn't find any other posts helping me out to remove the 'plastic clock mask' with the given 2 little tools and a screwdriver.
The manual states to insert the 2 tools until we hear a 'click' and then remove the mask with a flat screwdriver inserted just below the emergency button, but... even pushing with a certain strenght my mask doesn't move and I wouldn't like to destroy it.
The best could be to look at a picture of the "opened thing", just to better understand what damn I'm "pushing open" with the 2 tools to "hear a click", 'cos I cannot see what is there below this mask to keep it fixed. And I don't wanna break everything pushing too much!
Any advise would be very helpful, thanks!
Gianluca
PS: after having done - correctly but with pain! - the 'physical' nav hack, last year (with manual transmission - ie. without the many helpful pix we can find here on the automatic shift)... now I prefer to well study pictures before opening
Gianluca
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
I finally found a pix in this post:
https://www.clublexus.com/forums/sho...=251179&page=5
And I've tried this afternoon, but... with bad luck: I couldn't remove that damn harness and - just to make things harder - I tried pressing the map-DVD eject button without removing the 'cover'... May this be of help? Naaaa...
Result: DVD now is probably 'half-ejected' behind the cover and doesn't re-enter automatically, so the NAV is now even unusable (!).![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
I can't imagine how Lexus with such an expensive and nice car has designed such a "difficult" way of ejecting a DVD...![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
Any other posts/pictures/whatever to help me out? Many thanks again...
This is best left to your Lexus dealership.
There's a reason why Lexus made the process so difficult.
Or you could give Pocky a vacation package to Italy, and your issue will be solved.
In bocca al lupo!
(lol...did I say that right?)
In bocca al lupo!
Leaving it to my dealership... yes could be my last option ('cos it's far away from where I live), even 'cos I succeeded with the nav hack (really difficult with manual transmission and no pixs, believe me) and I cannot understand how could I be stopped by a plain, manual-supported, DVD ejection (!!!).
Okay guys, this is the best I could do to show in pictures how I removed that stupidly designed cover! Its not easy to remove, but very easy to scrap. Above all the best I can tell you is take your time, work one side at a time and always be mindful that one slip and you could end up with a fat gash across your clock face!
![](https://www.clublexus.com/gallery/data/3376/Removing_DVD_Cover.jpg)
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Wanna show me a link to where I can get some? I dont intend to remove that thing again anytime soon until I can get my hands on the 08 nav disc, but when I do Id like to try your method because the way I did it suct.
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Tech Info Resource
Mine needed no tape at all and no prying. Once I had the tools fully inserted it was easy to get the entire assembly to pull straight out the front.
I did this more than once, so I know it wasn't a fluke.
Here is the best way to access the nav DVD. Use the tool provided in your tool kit on one side at a time. Push it in until you feel it passes the first resistance. Then use a valve lapping tool right next to the tool and pull. It should come out easily. Then push the tool in on the other side and hold the other end (the end that already was pulled out) so it does not pop back in and again pull with the valve lapping tool. Really easy pulling one side at a time with the valve lapping tool.
Koz
Koz
Koz
Koz
