Fs: Complete Lms Superstreet S/C (Supercharger)
Originally Posted by Lexis11
Yup depending on if u want the wide band or not it is 3k without it and 4k with it.
"The kit delivers 7-13 lbs of boost @ 6,400 RPM with an adjustable air fuel ratio. Using the LMS FMU (fuel management unit) you are capable of adjusting your A/F ratio to 11.5 with 13 lbs. of boost without touching your factory ecu, injectors, or fuel pump.(note: head gasket or internals are necessary to lower compression on kits boosting over 10psi) Minor tuning and no chance of any check engine lights. Maintain your factory fuel economy at cruising speeds with 300+ horses at the tip of the gas pedal. "
To boost over 10lbs...you've got to change the headgasket and perhaps internals. Changing the headgasket is minor. Changing pistons and rods require a complete engine tear down. I assume that the 3-4k is for the fuel management system, pistons, rods, and labor?
Originally Posted by Gixxed_ATX
Why are you selling it? Is this the same kit that jp430 is using? Are the guys using this kit passing emissions?
Thanks.
Thanks.
Originally Posted by varcity64
he is selling b/c he parted his car out and no longer needed this... jeff (the seller) NEVER installed this kit on his car, but did purchase the blower (ONLY) from a moderator on this forum (LXOGOOD)... this is made by LMS, so if that is in jp430's car, then yea
The Kit for US 300 guys are the Powerdyne BD-11a. Which is the kit that i have.
This is a bomb *** deal right here. Sombody should really pick this up before it's too late.
Mo and Mikal thanks for answering, I was outta town for the weekend.
But ya this is a killer deal save a 1000, anyone who wants FI for their 300 needs this deal. Mo you really need this setup
