Tanabe GF210 Spring for 98+ GS300 and megan header
Springs are still new in the box, looking for 225 shipped on them.
also have a megan racing header, 02 sensor location has been repaired, but never installed or used.
after repair w/ burns stainless steel bung.....
looking for $250 shipped on this one.
thanks all
There are a total of four bungs in the header, one has a cap tack welded into place because it has fitment issues in the IS (chasis not sure about the GS), but thats why i added the other bung. the other cap shown is just screwed in for anyone not wanting to run the secondary o2's since you will need some sort of a simulator to not throw a check light w/ the header.
Originally Posted by KANEDL25
Because I am going to get other springs that don't have such a big drop for the back. I need a nice drop for the front like the one these provide.
GS3.0 if you could post pics of your car, ( i can even host if needed) it would be much appreciated.
KANEDL25 I would rather not split up a set, but let me check on something and get back to you on monday.
They will fit under the 400, but there is going to be a weight change between 300 and 400, so it may change the drop. I always thought the aluminum v8 actually weighed less than the cast iron inline 6 by a few lbs, but i could be wrong on that one. here are the specs off the tananbe site.
GS300 98-05
spring rate (kg/mm) FRONT 6.4/ Rear 5.5
advertiesd Drop FRONT 1.8 / Rear 1.3
part number TGF024
MSRP $310.00
GS300 98-05
part number TGF024
MSRP $310.00
Yes the IS and GS stock headers are identical I'm just not sure if the O2 bung that hits on the IS would have hit on the GS either way its just moved in to the number 5 running to give it some extra space.
ERICSC300
11-05-16 06:13 PM
